December 02, 2008, 02:41:51 AM
| | |-+  finally test drive my 383!!!!
Author Topic: finally test drive my 383!!!!  (Read 283 times)
1971scamp383
Rouyn-Noranda,Quebec
« on: June 30, 2008, 09:25:57 PM »
well......ive finally tried my monaco with the new engine,trans,diff.....ran pretty strong.....but.......when the car is in neutral i have a REAL GOOD throttle response....then i put it in gear(first gear)...i apply the brakes.....brings the rpm to 2500rpm and floor it realeasing the brakes...the car seems to have no power!!!!.....ive tried it a couple of time.....and only one time the car respond real quick and god it was great....that time the car seems to have no power like the other times but that time ive drop the gas then refloor it and man....the tires was melting even in second gear(like 150 feet of rubber).....was pretty nice....ok...the engine is brand new ...we have put the timing were it seems to be ok....(i know i have to use a timing light)...and also i dont have set the carb...this is a right out of the box edelbrock 1407...... is the timing can cause that problem?Huh? thanks
on the build....1971 plymouth scamp 383...
sportfury70
Re: finally test drive my 383!!!!
« Reply #1 on: June 30, 2008, 09:45:27 PM »
What are the specs of the cam, stall of the converter and what gear ratio?  It will take alot of torque to get that  big ole car movin.
Lewis
Steve DeTar
« Reply #2 on: June 30, 2008, 10:40:32 PM »
what gear and convertor?
Engine by DeTar
1971scamp383
« Reply #3 on: June 30, 2008, 11:05:06 PM »
here is my build.....383 .030 over...stock forged crank polish and new bearing....edelbrock double roller timming chain...edelbrock torquer aluminium intake(i know ...but hood clearance issue but not clearing with the spacer anyway \/][)....2'' 4 holes phelonic carb spacer.....comp cams xe274.....edelbrock 750 cfm performer series....mopar performance distributor kit with orange box....taylor 8mm plugs wires....full length hedman headers 1 3/4 ..3'' out....440source aluminium heads(2.14 1.81 )....keith black dome pistons..(6cc dome)...10.1cr right now.....2500 torque stall(stall at 2900 rpm)...freshly rebuilt 727 with b&m transkit(shift kit)...3.91 rear gear with locker lock right     thanks all
« Reply #4 on: June 30, 2008, 11:16:35 PM »
yeah, get a timing light.
my64dart
« Reply #5 on: July 01, 2008, 03:37:16 AM »
Hi,
  You really can't adjust anything until you know the timing is right on. I set mine at 36* @ 3000rpm  That should be about what you need also. Then you can try different things like carb adjustments & stuff. Your combination should be able to burn up them tires pretty good.
       Jim
ksdartguy
« Reply #6 on: July 01, 2008, 09:03:17 AM »
 agree  Start with the timing. You will need more pump shot from the carb with a spacer under it.
Try drilling the shooter a couple thousands larger. If response in neutral is good, you are'nt far off.
You might need a bit more stroke in the pump lever travel too.
 bbd sign
coors00
« Reply #7 on: July 01, 2008, 09:05:56 PM »
Ditch the spacer, It is nothing but a problem. Install it later if you want less HP.
