Topic: Moving battery to trunk (Read 746 times)
5258
When moving the battery to the trunk how do you guys wire it up? Is there 2 wires coming from the battery (one to starter and one to selinod) or just one wire to starter?
Wiring is not my favorite job, Any pics will help.
Thanks Mike
5258 Performance Shelbyville, Tennessee "Where the MOPAR factory built and race ready hotrods live again"
Prodart
Just the main cable everything else bootlegs off that. That way you kill everything with a disconnect.
Wasn't planning on running a disconnect, Will that make a diference?
Thanks Mike
5258
Also, How are you guys doing the ground? Ony to frame or all the way back to the motor? My motor is grounded with the stock strap?
Thanks Mike
Capt Jack
I run a ground to the frame. I also have a solid ground from engine to frame.
rules where I race require an external cut off when a battery is relocated. I prefer having one myself. it cuts off from the outside, but you have to open the trunk to turn it on. keeps someone from being able to come by and just switch it on. the cutoff kills both the + side of the battery and the alternator wire.
the + side connects to the same place it did before I moved the battery.
That One Guy
I'd say run a shutoff, you'll need it if you plan on doing anything with the car, like running it at a track. ground it to the frame, and we just ran one wire to the solenoid, and branched off from there.
"I'm your Huckelberry" I need someone to look forward to.
5258
Stock set up has one wire to the starter and one wire to the solenoid. To get this straight I'm running a mini starter I should run hot wire to the solenoid only and jump it over to the starter.
Thanks Mike
cu440da
Just remove your old positive battery cable and replace it with the new one coming from the trunk. Everything else stays the same.
You will need a cutoff, and probably sealed batt box or trunk. The track I ran at could care less about anything, but requires those with relocated batteries.
'67 Notchback- 12.85 @ 109mph
67 dartgts
Hello: Try this.  Maynard
5258
Helps alot.
Thanks Mike
5258
Maynard,
I'm running a single wire alternator, does that change anything?
Did I mention I hate wiring.
Thanks Mike
jacks62440
Hello: Try this.  Maynard Anyone , Please correct me if I am wrong !!! Believe me, I don't know anything about wiring. But , In the picture I believe the main power cable to the starter is always hot. That could be trouble down the road. My expierience has taught me that " Shit Happens " If you had a remote starter seloniod near the battery and ran a 8 guage wire to the starter seloniod it would only be hot when you are cranking it. Correct me if I am wrong !!! Jack
Jack
67 dartgts
Hello: Well that makes at least 3 of us that are not experts, and I hate wiring also. I use this system and have had no problem with it..before I went to this my driver emergency kill switch and one wire alternator would run on when I shut it off.
any feedback experts?
Maynard
5258
My stock set up had a hot wire running to the starter and a smaller wire running to the starter solenoid, Not much diferent from this set up above. I completed wiring yesterday, tested lights and turn signals (cut harness and routed outside inner fender). So far so good. Engine bay looks clean. Hope to try to start up today. Waiting on parts to complete my  set up.  Mike
abqdart
I am IN THE PROCESS of doing my wiring right now. I plan on going, BAT+ to kill switch to a ford solenoid to the starter( mini starter) I jumpered the wire from the start relay to the big post on the starter motor. From the "S" terminal on the solenoid I have my ignition switch (push button). I will see what happens and let ya'll know......
Rio Rancho N.M 87144
jacks62440
Good luck on that. Like I said before I don't know much about wiring , but if I read right, I am wondering about the jumpered the wire from the start relay to the big post on the starter motor. I hope it works for you !!!
Jack
abqdart
On the thread "Another dumb wiring question" It was suggested to bridge the trigger terminal to the main lug on the starter, then run a 1 gauge wire from the main lug up to the post on the Ford Solenoid. Its been done by many folks on this board that went a different route than the factory wiring, which keeps a constant "HOT" on the starter main lug. So, far the wiring is going really good. I will get pics up when I am done.
B-onefan
Any pics on this settup? I am planning on doing the same thing with a Ford solenoid. I am running a + cable from the trunk and going to the solenoid, off ov the battery side of the solenoid, I will run my power to the rest of the car, and off of the switched side, run a #4 wire to the starter and jumper from the main lug to the small lug on the starter. Now, the wire that used to run to the solenoid from the Mopar starter relay goes to the Ford solenoid and connects WHERE? , S or I terminal? I believe it is the S. Anybody know?  Thanks
73 Duster 74 Duster 76Duster 67 Barracuda 68 Barracuda 68 Dart 69 Dart 72 Dart 78 Trail Duster 1999 Ram 1500 Sport QC 4X4
The pull in wire from your starter goes to the S terminal on the Ford solenoid. Jump the starter pull in terminal to the cable lug and when the Ford solenoid closes, the starter solenoid sees full battery voltage. The car will start like never before.
One really nice thing about this mod is that the section of cable going to the starter is dead all the time. It's only hot during cranking, a big plus in my book when you have headers.
sleeper
1969 Barracuda Fastback 1969 Chrysler 300 1998 Dodge Ram 1500 Quad Cab 2003 PT Cruiser 2005 Dodge Sprinter
B-onefan
 Thanks for the info, I will try it this weekend.
B-onefan
I'll check thes out. Thanks for posting
Jim13
San Antonio, Tx
Thanks for posting all the helpful info. I am in the middle of this myself.
