October 11, 2008, 09:16:56 AM
| | |-+  A500 or Gear Vendors OD
Author Topic: A500 or Gear Vendors OD  (Read 198 times)
7Dart2
« on: July 01, 2008, 02:37:10 PM »
I am running a 540 hp small block in a 72 dart and I have a 3200 turbo action stall and a rebuilt 904 with low gear set and 3.23 ratio. I want to get an od but I would like to know the best route to go.
Should I go with the a5oo or use the gv?
I need lots of advise.
ksdartguy
Re: A500 or Gear Vendors OD
« Reply #1 on: July 01, 2008, 04:12:56 PM »
Check with http://www.smrtrans.com/
They sell both, but specialize in the 500/518s.
scaldeddog
Lake Helen, Florida
« Reply #2 on: July 01, 2008, 09:50:57 PM »
Gear Vendors aren't cheap, but you won't kill it.
Smokem' if ya gottem'
822 post on the old board
abodyjoe
South Jersey...
abodyjoe
« Reply #3 on: July 01, 2008, 10:03:11 PM »
the 500 has a better OD ratio.
7Dart2
« Reply #4 on: July 01, 2008, 10:06:08 PM »
The a500 was qouted at 1650 from a local shop. I also quoted a stall convertor from PATC for 795. The GV unit is 2695.
Dynamic convertors told me that with the motor setup I am using, that I would like the GV unit better. He stated that he could only build a convertor with 2600 stall for that tranny.
abodyjoe
South Jersey...
abodyjoe
« Reply #5 on: July 01, 2008, 10:09:00 PM »
here play around with the different options and see what you would like best.     http://www.bigblockdart.com/techpages/speedtire.shtml
blown71duster
« Reply #6 on: July 01, 2008, 11:50:39 PM »
 I think it also depends on what the car will used for , a street only car could get by more with a 500/518 tranny. There is a lot of guys on the diesel forums building the 518's behind mega torque cummins. Thats what I am using in mine, I bought PATC's kit which is supposed to upgrade to 700hp level and I upgraded the planetaries also. I found a 518 core for $75 and doing it myself will have around $1500 including an ultra bell for big block .  The 500/518 both have a .69 overdrive ratio which is better than the gear vendors.
Or if money wasnt a problem you could bolt on the gear vendors on the back of a 518 for double overdrive .54 ratio   Grin
1971 Duster 440  Single turbo
375InStroke
« Reply #7 on: July 02, 2008, 12:28:28 PM »
Where did that come from?  It's not indexed.  How many other hidden pages are there?
abodyjoe
South Jersey...
abodyjoe
« Reply #8 on: July 02, 2008, 01:17:19 PM »
  thats coming as soon as bill gets a chance.
blown71duster
« Reply #9 on: July 02, 2008, 02:02:12 PM »
Anyone that is considering rebuilding an overdrive 518, found this blog on the net very complete and great info,I printed it out and put into a binder..
http://joelsgarage.blogspot.com/2008_02_01_archive.html
