August 28, 2008, 07:22:02 PM
| | |-+  Kinda silly question: A body four speed in a Charger?
Author Topic: Kinda silly question: A body four speed in a Charger?  (Read 135 times)
Lars
ATX
« on: July 08, 2008, 09:44:46 PM »
I plan to (hopefully) finally get started on my Charger sometime in the next few months. I have the engine covered (440) have the rear (8 3/4) but no transmission. However I do have an A-833 sitting on the floor out of a 72 Dart. The Charger was an original /6 904 car so I imagine the mount will match up, but what about the shifter? Will it be too funky, or would it work? I'd just stick it in and find out, but I don't have a bell housing yet, if I'd need to track down a B body specific unit I'll just go with a 727.
Thanks
speeder440
Re: Kinda silly question: A body four speed in a Charger?
« Reply #1 on: July 08, 2008, 10:15:02 PM »
Thanks
What year Charger?
Lars
ATX
« Reply #2 on: July 08, 2008, 10:18:25 PM »
Oh yeah, 72.  \/][
speeder440
« Reply #3 on: July 08, 2008, 10:33:20 PM »
 Smiley Thats not a silly question,its a good one,if you want a car that will  4 speed .Get some red lines tires and leave 80ft.marks in the front someones house,that car can.But sometimes if you wanta bracket race get an  automatic. I like Crazy Larry's Charger 71' I think.
« Reply #4 on: July 08, 2008, 10:43:14 PM »
The shifter will come up through the floor in the wrong place and a custom floor hump will be required OR a custom shifter mounting plate with b-body shift rods.
Lars
ATX
« Reply #5 on: July 08, 2008, 11:46:24 PM »
Will it be to far forward?
« Reply #6 on: July 08, 2008, 11:51:52 PM »
Nope, too far back. The problem will be in clearing the trans cross member with the shift rods, and not the bolt-in member. The 1-2 and 3-4 rods go ABOVE the weld-in crossmember so a custom hump or shofter mounting plate will be necessary.
« Reply #7 on: July 08, 2008, 11:54:10 PM »
Actually the 72 Charger may use the E-body mounting position, so if this si correct, then the shifter will be too far forward.
Lars
ATX
« Reply #8 on: July 09, 2008, 12:14:23 AM »
Yeah the 71+ B bodies shared a lot of E body parts IIRC.
Adam
adampietkiewicz@hotmail.com
« Reply #9 on: July 09, 2008, 05:52:44 PM »
What about length? I Don't know anything about automatics, but I do know that if your Charger had a B-body 4 speed in it, and you swap to an A-body 4-speed, the a-body trans is shorter and will require a longer driveshaft.
Perhaps the 904 is the same length as an a-body 4-speed? I'm sure Jim can chime in here....
Adam
Lars
ATX
« Reply #10 on: July 10, 2008, 03:22:26 AM »
Adam
The A body 833 is the same length as the 904, since this car originally had a 904 in it thats what made me consider the swap.
