December 04, 2008, 11:48:44 AM
| | |-+  Hughes Engines Distributor Shaft Collar
Author Topic: Hughes Engines Distributor Shaft Collar  (Read 274 times)
Pro Street dart
« on: July 12, 2008, 03:45:24 AM »
The thing works great. Timing used to jump 3-4°'s  when I set the initial timing, now it's rock steady.
http://www.hughesengines.com/partDetail.asp?partID=12121
chryco
Re: Hughes Engines Distributor Shaft Collar
« Reply #1 on: July 12, 2008, 08:49:15 AM »
I`ve used those for years , Ed Hamburger 's For 340`s/360`s  Only used to sell them . A rod coupling will also work.
Well worth the effort to install .
   Chryco
nothingbutdarts
« Reply #2 on: July 12, 2008, 10:42:48 AM »
Do they seem to add any wear to the distributor?
69 Swinger 340
Soon to be 69 426 Dart
80 Crew Cab gas hawg
01 DIESEL Hauler
   Bailey, Colorado
ksdartguy
« Reply #3 on: July 12, 2008, 11:45:52 AM »
No, They just keep end play from effecting timing.
I bought collars from a local brg supply. Same thing and only a couple $$$ each,
496dart
« Reply #4 on: July 13, 2008, 10:55:14 PM »
i need one of those--if i go to the bearing store ,  what exactly do i ask for ?   shaft collar?
nothingbutdarts
« Reply #5 on: July 13, 2008, 11:10:58 PM »
A bearing lock collar
69 Swinger 340
01 DIESEL Hauler
   Bailey, Colorado
496dart
« Reply #6 on: July 13, 2008, 11:40:14 PM »
thanks buddy !
drinks
z1bigtom
« Reply #7 on: July 14, 2008, 07:26:35 PM »
Are these needed for race motors only? Will motors that spin under 6K benifit from this also?
