Topic: internal/ external balance (Read 658 times)
I can't help you with the pics, but I can tell you this... I built an internally balanced 360 for a friend many years ago and it is still running today.
If I remember right, there was quite a bit of Mallory Metal involved, so it was a little pricey.
BIGFISH
If I'm remembering correctly there are 2 different balancers (ones lighter than the other) for the 360. I think the lighter one is '71-'74 and the heavier one is from '75 & up. See what year your block/crank is and check a bunch at the boneyard to verify.  All are external balance unless they have been rebuilt and internally balanced.
64'5speed
block is a 75. I got the heavy one.
Alexandre_Garcia
All LA 360 have the same inbalance, use the damper U like most. Ones have the inbalance at the hub, others in the outer ring. I'd rather have the ones with the hub with a big cam shaped weight but it is heavuer and harder to find. Magnum 5.9 has another inbalance weight and is not suited to the older LA 360 engines
bwells
If you're using a tranny off of an internally balanced motor, make sure to get the correct flexplate also. B&M makes them, and Summit carries them.
If you need a damper, I might have one off a late eighties LA 360 that I pulled from a ramcharger.
64'5speed
going manual trans. still need a flywheel but I got plenty of time before I need it badly. Damper situation is taken care of.
Alexandre_Garcia
64,
In summitraciong they carry this: DCC-4529110, is the correct flywheel for a stock, external balance 360 LA engine, will not fit a Magnum 5.9 that has a different balance factor, it has a 130 ring, works with 10 or 10.5 clutch, 270$. If You have a Magnum 5.9L you should use a P5249842 , especifically made for this aplication, 354$ There are a bunch of other part numbers fitting the same criteria in a search there, but these are the ones You need, right out of the box, not requiring a new rebalancing job on the engine.
