Topic: Offset Cylinder Head Dowels (Read 118 times)
Tof
Hi all , excuse me for the disturbance and my pitiful américan but this is my question , récently y see this part ..... ..... and the question , what is the utility of this part ? I see the fonction ( doing a offset at the header) but After hard reflection (  ) for what problem at the origine ? Thanks , Tof
The "Dartspirit" is good for me!
farmington
are you sure that they're not offset bellhousing dowels? Those have a use. Can't see a use for offset head dowels.
When in doubt, Whip it out!
68S
Offset cylinder head dowels are used to properly locate the combustion chamber over the cylinder. Factory tolerances can be way off the mark sometimes so do not take anything for granted.
Pat
if the are for the "b" motor heads they are to move the heads to place the valves more in the center on the bore. this way you can get a bigger valve in the heads and have less strouding at the edges of the chamber, like the sm blk moper has. if the are for the bellhousing they are to center it to the crank. this is especially helpful in a clutch car.
