October 10, 2008, 07:23:41 PM
| | |-+  Leaky oil filter adapter on a sm blk
Author Topic: Leaky oil filter adapter on a sm blk  (Read 105 times)
71 swinger
« on: July 13, 2008, 05:55:55 PM »
Has anyone ever had a problem with the adapter on there small blk leaking? If so what did you do to rectify the problem?
I cant get mine to stop leaking around the adapter itself.
Any help would be appreciated.
Danny Bellmore
Discouraged Dart Owner
lake worth, florida
55robert@bellsouth.net
Re: Leaky oil filter adapter on a sm blk
« Reply #1 on: July 13, 2008, 06:34:02 PM »
take it apart and clean everything then use silicone to seal all the gaskets on both sides and make sure you have all the gaskets in there.
« Reply #2 on: July 13, 2008, 07:09:13 PM »
There are three gaskets and to my knowledge can only be found at the dealer.........
sunsetdart
us4ever365@hotmail.com
« Reply #3 on: July 14, 2008, 08:04:17 AM »
make sure you tighten the big nut that holds the plate to the block too
Long Island, NY
« Reply #4 on: July 14, 2008, 09:18:53 AM »
I could swear I used to get those gaskets in a Fel Pro kit, but that was twenty years ago.
« Reply #5 on: July 14, 2008, 05:57:11 PM »
  It's nice to see that I'm not the only one who thought that fool bolt was tight enough. I had the same problem. The real fun was in dropping the header to get access to the bolt with a wrench *mumble*. Then reassemble everything and try again. Each test equates to a reheated header *mumble, mumble*. I actually contemplated removing the stupid thing and using a shorty filter but it sealed up on the first try. It did make a mess on my "Jet hot" coated headers though *sigh* Some days, you could just scream....   Frustrated
sportfury70
« Reply #6 on: July 14, 2008, 06:15:43 PM »
I had that happen before.  I ended up using silicone and letting it sit overnight.
