Topic: 360 (Read 464 times)
mopardart71
360
« on: July 13, 2008, 10:02:44 PM » |
again need a 360 shortblock or complete running engine,what do you got?thanks will visalia california
dergrosse372
Re: 360
« Reply #1 on: July 15, 2008, 02:20:22 AM » |
I have a Herb Mccandless .060 over 360 10.0 pistons, 292 factory cam& lifters, pan, etc. Heads are ported 1973's with new 2.02 int 1.60 ex with 600 lift springs, new m-1 intake.Motor never fired. I can send pictures if interested asking 4000 for all or best offer. I am in Apple Valley, Ca, near I-15 and 58, call at 760-247-1157. George
Baxter61
Re: 360
« Reply #2 on: July 25, 2008, 06:04:49 AM » |
Should be together next weekend(getting back from machine shop on wed) .040 over 360, rebuilt rods, polished crank, Speed-Pro H405CP pistons, Mahle rings, summit balancer(the $240 one) and b&m flexplate, rotating assembly balanced for use with neutral converter, new block hardware, new bearings, new water pump, comp cam, .507/.510 284/296 on a 110 lsa. No oil pump, pickup, pan because I dont know what car its going in. I have a topend I can put on for extra. Approx comp ratios with a 4.100 bore gasket .040 thick 60cc head, 10:1, 65cc head, 9.6:1, 70cc head, 9.25:1 Email AmoB64@msn.com if interested. Shipping from Portland, OR.
mopardart71
Re: 360
« Reply #3 on: August 24, 2008, 09:56:29 PM » |
a little expensive for my budget taste
physixx
Re: 360
« Reply #4 on: August 25, 2008, 08:13:52 PM » |
I've got a fresh 360 that was all new with the KP hypereutectic pistons, moly rings, high volume Melling oil pump and screen, factory 2.02 J heads, aluminum intake,etc that the owner messed up when he did the intial startup. Didn't have the ignition hooked up right, kept trying to start it and when he finally did and drove it, he wiped out the cam in a matter of a few miles. To help him out, I'm in the process of freshening it up so it'll have new rings, bearings, new cam, lifters, everything washed with soap and water, the whole deal. I'd like to get $3000 shipped from Edison, NJ when it's done. I can give you more details and pics if you're interested. Ken Edison, NJ rider1454@aol.com
