Topic: Diameter drain brake (Read 298 times)
Tof
Hi all , excuse me for the disturb but for the restauration of my dart i want have the diameter (Interior and Outside) of the drain of brake please .
In france i can have in diameter interior : 1/8 or 3/16 .
Thanks and kiss at your ass !
Tof
The "Dartspirit" is good for me!
That One Guy
well, for starters, welcome, I haven't seen you around, and don't worry, you aren't disturbing the peace, we love to help as much as possible, which usually means, someone on here will be able to answer your question. I can't answer it right now, but I would like to ask, what is "drain of brake"
"I'm your Huckelberry"
rhood
bleed screw?
Tof
Thanks misters , indeed my presence is light here you can have my works here http://www.bigblockdart.com/index.php?topic=28915.msg279666#msg279666 , i am Mecanician/Bodyman in the North of the France . well my question is not for the bleed screw , i want the diameter of the pipe ( not the "drain" excuse me ) interior or outside , its not a problem i can to convert . Thanks , Tof
That One Guy
Ok, well, I'm pretty sure it's 3/16,
Tof
Yessssss ! , i can rebuild my brake system now , thanks !
Tof
yup 3/16 is correct
The 10 watt engineers (dim bulbs) like to make things as difficult as possible, so rather than tell you the ID (internal dimension) they sized the lines by the OD (outside dimension). I don't understand it too much either; other than it's just another way to confuse you and get you to take it to the dealership so they can make money and make you feel silly at the same time.
Happy bending
MoPar_or _NoCar
Round tubing "not pipe" is measured OD so the hose that is measured ID will fit snug. Round and square pipe is measuered ID as to square tubing is OD.
