Topic: What should I paint my K with? (Read 468 times)
ValiantOne
Started working on my K frame tonight. Got her all stripped down. Planning on sandblasting it. Then rewelding some of the less than ideal seams. Boy they did a crappy job of welding that thing up.
anyhow, what should I paint that puppy with that is tough? I've heard of por-15, but I thought that was for use over rust. Will it work on a freshly blasted surface? Is there something else that I may like better.
What have you all used with good success?
Thanks,
CE
rjsjea
Powdercoat it.......it will look better than brushed on POR15 and adhere better
Thin White Duke
Either powdercoat or that 2 part chassis epoxy that Eastwood sells.
ValiantOne
There is a guy who does powder coating locally. How does it compare  -wise to the epoxy, por15 type of coatings?
I had mine powdercoated for 75 bucks about ten years ago. It looks perfect.
blow[n]dart
this may be completely shunned, but I dont have the money to get anything powdercoated, and besides that theres no one around here that powdercoats anything that size, ive had great success with stripping it to metal, cleaning it like crazy with prepall and laquer thinner, then spraying it with engine paint. it looks good, sticks well, is heat, rust, and grease/gasoline resistant. all ive used it on look great...even after time. plus if you scratch it or something, you can fix it with out having to take it back to the powdercoter. just my 2cents worth...
If it comes down to doing it yourself, I've had great success with Rust Oleum. Very tough paint. Por 15 is great to use underneath, but it should be covered up.
thebankerstoy
Hi Chris, I had all of my 66 Coronet's front suspension parts that could be powder coated done back in 2000 when I did a complete front suspension rebuilt and it ran me a little over $200.00 to do everything including my K-frame. It still looks like brand new 8 years later and with the powder coating, the suspension parts are MUCH easier to keep clean.  Spend the money ONCE for the powder coating and it will look good for you for a LONG time my friend!  Richard
Yes I agree. You can also prime it with etching primer and then follow it up with a 2 part catalyzed paint like eastwoods. Also, a local guy here is dirt cheap on powdercoating, he could do it for about $100.
ValiantOne
Thanks guys. I'm going to check with the powder coating guy and get a quote. It it is too much  I will break out the black rust oleum
west
if you have other stuff to be coated at the same time you will get a better deal. paint is better than por if there is no rust,p.o.r doesn't like smooth metal surfaces
mopowers
For what it's worth, I shot mine with Zero Rust mixed 3:1 w/ hardware store acetone. It runs about $60 a gallon. Then I shot a couple top coats of gloss black rustoleum professional straight from the rattle can. It looks good, but has no road miles yet. A lot of people have issues w/ zero rust drying. But mine dried very quickly even in 60 degree temps. It dried to the touch in about 30 minutes or a little less. It's very hard too. I just used 3 or 4 very light coats.
Thanks guys. I'm going to check with the powder coating guy and get a quote. It it is too much  I will break out the black rust oleum  yOU KNOW WHAT WOULD BE CHEAP AND TOUGH, GET A CAN OF GREEN SPRAY ETCHING PRIMER AND COAT IT WITH EASTWOOD CHASSIS BLACK, SHOULD BE ABLE TO GET IT ALL FOR UNDER $20
jamesdart
ive been using that eastwood chassis black over epoxy prime lately, no road miles but it sprays pretty nice right out of the can. last time around i did all suspension parts with rattle can engine paint, and it held up ok, i guess. then i started bombing everythign with rust oleum cut 20% with acetone, that seesm to hold up pretty well and you can lay it down nice and heavy. i looked into powedercoating, once it was a friend of a member here, new business, i felt the guy tried to rape me.
blow[n]dart
its a little dusty in the pic...but heres mine wit high temp engine paint
doug 371
centari  ...it smells good too
A13Dart
I used the Eastwood Chassis Black.
ValiantOne
I'll bet you did!!!  You got a pic of the whole K? Someone must have done some welding on that K. It looks way to good to have come from the factory like that. Tell me more!  CE
A13Dart
I'll bet you did!!!  You got a pic of the whole K? Someone must have done some welding on that K. It looks way to good to have come from the factory like that. Tell me more!  CE I moved the mounts back as per the tech pages for the big block conversion.
ValiantOne
Or maybe.......... A BRUSH................
