Topic: Comp Cams oil additive (Read 194 times)
tpits1
Ok dumb move on my part I added 2 bottles of the comp cams oil additive to my car durning the last oil change yes stupid but was in a hurry does anyone kmow/think I should drain all the oil out and or can i run it with 2 bottles of the attive ?? Thanks
That One Guy
what does the additave do
"I'm your Huckelberry"
tpits1
It adds what the oil manufactures have taken out of the oil so you dont wipe a none roller cam and the camshaft itself
That One Guy
I don't think it should be too bad, but don't take my word for it
satellite65
Read the insructions on the bottle to see if there are any warnings. IMHO, I don't think it's going to be a problem but don't take my word for it. Personally, I think we're all getting a little paranoid over this "oil" thing.
tpits1
I would agree with you and the oil additive thing but unfornatly My motor builder Erick at JB motors in Poughkeepsie (aka Bobby Ingles shop )who builds pro stock motors for a living has wipped several cams durning his dyno sessions so since i could not afford a roller cam I am using this additive, should have went with the roller instead, something to do next time i do a rebuild
satellite65
I'm in the same boat. Rollers are pricy and I have other car related things to do this  with so that's that. I think this business of tearing up cam lobes is mostly related to high lift cams that require insane spring pressures. Anyone out there have any problems with wimpy, sissy cams like the one I want to use (.488" lift intake / .501" exhaust)?
64'5speed
my neighbor wiped out a cam 200 miles after break in. he didn't use any additives and used motor oil formulated for new cars. granted it was a ford. but you'd think for 10K you could get a smallblock that didn't wipe out lifters. then spent even more money to go full on roller so he didn't have that problem again. then a week later I fired up my solid lifter /6 with no problems. I put in E.O.S. for break in
Womanator
1 bottle to 5 qts of oil.So use accordingly.
