October 12, 2008, 11:03:52 PM
| | |-+  vacuum leak?
Author Topic: vacuum leak?  (Read 68 times)
3404bbl
vacuum leak?
« on: July 16, 2008, 11:29:53 PM »
I've got a stock 360 with a cast iron 4 barrell manifold. It idles pretty rough. I noticed some oil around one of the center intake bolts. I don't have a vacuum gauge, but I'm thinking that may be my problem. It's a new rebuild.
Thoughts? Should I just go ahead an dput new gaskets on it?
Long Island, NY
Re: vacuum leak?
« Reply #1 on: July 16, 2008, 11:35:38 PM »
I would certainly take it apart carefully and see if it's drawing oil from the mating surface down an intake port. I don't know that I've ever seen oil come up an intake bolt.
MVRCorp
Re: vacuum leak?
« Reply #2 on: July 16, 2008, 11:41:08 PM »
Get a can of WD-40 or engine cleaner and let the engine idle. Spray around all the mating surfaces including the carb base. When you here an RPM change you have located the leak. No RPM change, no vacuum leak. Simple check.  Grin
67dartgt
Re: vacuum leak?
« Reply #3 on: July 16, 2008, 11:51:14 PM »
I have! A stock 318 with an aluminum 4 barrel manifold. I saw someone somewhere seal the threads on the center intake bolts so that it doesn't happen. But it would puddle at the bottom of my intake from the center bolts.
- Don
67dartgt
Re: vacuum leak?
« Reply #4 on: July 16, 2008, 11:52:14 PM »
PS. Not to say that sealing the threads is the right way. i didn't do that. But my leak didn't affect the idle. My idle problems were an overcarb'ed 318 with a single plane manifold.  taunt
