November 22, 2008, 01:31:11 PM
| | |-+  adjusting valves with hydraulic cam
Author Topic: adjusting valves with hydraulic cam  (Read 333 times)
grudd440
« on: July 18, 2008, 12:45:11 AM »
hydraulic cam and roller rockers. what is the easiest way. which ones can i adjust on the first revolution of the crank. and after engine is turned 180 degrees?
440 DusterDemon
Go Phillies!
Re: adjusting valves with hydraulic cam
« Reply #1 on: July 18, 2008, 12:58:39 AM »
id do the exhaust valve about half way to the top of the compression stroke  and just follow the firing order..........then the intakes about half way up the exhaust stroke.......make sure you spin the engine in the rite direction
grudd440
« Reply #2 on: July 18, 2008, 01:14:50 AM »
if i were to start at top dead center of the compression stroke and set the valves on #1 cylinder, then turn the motor and set #8?
440 DusterDemon
Go Phillies!
« Reply #3 on: July 18, 2008, 01:52:01 AM »
ya wanna make sure the lifters are completely on the heel of the cam......id think if #1 exhaust is in position, #6 intake should be also...and so on; .....im sure  others have a may have a different technique, but it works for me.
grudd440
« Reply #4 on: July 18, 2008, 08:32:26 AM »
on my brothers chevy, he has a book that tells him all of the intakes and exhaust valves u can do at one time. it makes things easy.
440 DusterDemon
lucasdart
« Reply #5 on: July 18, 2008, 08:56:49 AM »
I just do it one cylinder at a time. It's a little more turning the motor over, but it's pretty fail proof. Just spin to where the intake is rising and almost at the peak lift, then do the exhaust. Then spin it over a rev or two then when the exhaust is almost at the peak, do the intake. It's never failed me before. I have a trigger that you hook to the starter so you don't have to crank with a ratchet.
ksdartguy
« Reply #6 on: July 18, 2008, 10:17:44 AM »
Dont know how well you can read it but here is mopar sticker that shows valves and rotation.
grudd440
« Reply #7 on: July 18, 2008, 07:01:07 PM »
cool, im going to go adjust them now.
440 DusterDemon
satellite65
« Reply #8 on: July 18, 2008, 07:16:53 PM »
THANK YOU!!!! I've been looking all over the place for that. I know I had one of those laying around here somwhere.
dusterdarryl
« Reply #9 on: July 19, 2008, 12:43:18 AM »
dont forget big and small blocks have opposite rotating dizzys, bbs are anticlockwise
grudd440
« Reply #10 on: July 19, 2008, 02:28:48 AM »
i adjusted the valves as per the mopar chart and per the crane cams recomendations. i adjusted them 1/2 turn past zero, but had no compression Huh. i then set the valves at zero and it fired up Smiley and proceeded to break in the cam. has anyone heard of this?
440 DusterDemon
« Reply #11 on: July 19, 2008, 10:27:21 AM »
Sounds like you adjustde them too much much and the valves weren't closing.  remember- vero lash just means no play.  It's possible that you  colapsed the lifters and gave it 1/2 turn more.
grudd440
« Reply #12 on: July 19, 2008, 01:13:03 PM »
yes, very true.
440 DusterDemon
Go Phillies!
« Reply #13 on: July 19, 2008, 03:31:27 PM »
tighten till they just start to collapse the lifter.....then 1/2 turn
fishy68
« Reply #14 on: July 23, 2008, 02:29:29 AM »
Sometimes the lifters get hydra locked also so even when you adjust them right they hold the valves open for a little while until they bleed down. I had that happen on a Chevy V6 in a forklift once. Had to pull the heads to have them rebuilt and when I put it back together it didn't have any compression on 5 cylinders. Don't ask me why one cyl. had compression??? They were non adjustable valves BTW. After I cranked it over awhile cylinders started coming alive. Finally I got 4 cylinders to fire enough to start and within about 2 minutes the other lifters bled down and it hit on all 6.
Here's a link to a page on Moparts that has the valve adjusting chart.
http://www.moparts.org/Tech/Archive/motor/14.html
coors00
« Reply #15 on: July 23, 2008, 07:56:22 PM »
Spin the pushrod with your fingers as you tighten. When the spin stops, it is at 0 lash; then pre-load.
