Topic: WOT Air fuel Ratio (Read 82 times)
hyperdart
Hi guys,
I 13.0 to 13.5 OK for WOT? My 440 engine makes the most power at 13.0-13.5 or should i set it to 12.5 A/F ? It makes about 30 HP less at 12.5 what should i set it at?
Thanks,Brian.B.
FAST Man EFI
As long as the plugs look good with no speckling and you're not detonating, you can leave it where it is. The ideal WOT A/F ratio is 12.9:1, but no two engines are the same and cam overlap plays a big part. I can see the HP dropping off if you go to 12.5:1 but that's actually a big change. If it's happy there, without causing any problems, go for it.
