Topic: trany shifts real hard (Read 292 times)
dartracer
When I took my Barracuda down the driveway, it would not shift out of first. On my way back I got on it a little more. When I got to around 4000 rpms it grabbed second real hard, almost with a bang. Trans has a TF2 in it. Do I need to play with the Kick down some more? Or could it be something else? I got this from a freinds street strip car. about one year old.
Did you just install this?
I actually know very little about autos, but if no one else chimes in, I'll ask my friend Pat on Monday. He runs a trans shop.
dartracer
Yes, just put it in the car.
Dono
Did you use the same converter as he or one of your own? Check the line pressure.
oldkimmer
..................YES U need to shorten the KD linkage, something may b binding ,or u may have the wrong linkage, or the govenor may b hanging up from sitting......or they may have set the line pressure to hi to begin with 4 the street.....kim.......
Hemi GTS
Shorten Your linkage at the carb. This is also refered to kick down linkage, the correct name is throttle pressure control linkage. By shortening it it lowers the pressure in the trans that holds the clutches an bands on, thus allowing the governor pressure to rise faster enabling a shift to occur at lower road speed. DONT operate the trans. with this linkage disconnected, to do so will burn it up.The only way you can operate it like this is with a manual shift body.
ksdartguy
 Yes start by shortening the linkage. Its pretty sensitived. The lower throttle pressure will lower the rpm and the shift intensity too. Rick
nothingbutdarts
Bailey, Colorado
welcome to "bOb built".
