Topic: 440 oil pan (Read 208 times)
jam420
hi guys 1st post. i need to know what aftermarket pans will fit a 68 dart with a 440.thanks
click on the tech pages bottom at the top of this page and scrool down to references on the left bottom, hit tips,trick and tight spots, go to oil pans.
oldkimmer
,...............Welcome to the block..........the best ppl r here............kim.........
ari440
milidon low profile 7 quart oil pan using it with a external oil line too
gearhead01
If you don't fail, you cannot succeed.
ari440:
Did you have to notch or cut the K frame for pan clearance? If so, do you just have to cut the lower lip on the K frame, or cut into the vertical section of the K frame?
Thank you.
John
1968 Plymouth Valiant 2-Door Post Bracket Car In Progress 1971 Plymouth Satellite Sebring Plus, 383, Auto 14.46 @ 94.53 MPH
ari440
yes you need to cut the pass side lip out
did this when I had my 340
1/2 cut off the lip so it looks squared off
codfish
Online
I have the Milodon 30930 pan in mine. Clears everywhere. Engine practically fell in!!!!!!!!!!!  codfish
 DRIVE A HYRID. I NEED YOUR GAS!!!
gearhead01
Thank you for the information.
John
jam420
thanks for help guys ordered pan yesterday!!!
