October 10, 2008, 07:32:22 PM
| | |-+  318 is finally in, with issues...
Author Topic: 318 is finally in, with issues...  (Read 127 times)
bwells
« on: July 21, 2008, 05:51:11 AM »
Well, I finally got my 318 back together and into the car.  Crank journals turned 20 down, all new bearings, new piston rings, comp cam, 160 duration w/ 454 lift, new valve springs, retainer, locks, and seals.  Went to fire it, and it started right up.  Sounded pretty good too.  I ran it for about 20 seconds and had to shut it down due to water leaks from the head bolts.  My buddy helped me put the motor together, and we put a sealer on the bolt threads, but now I'm wondering if this didn't work for some reason.  Which head bolts go into water passages?
Sorry I don't have any pics, but my camera decided to go for a swim the last time I went fishing... Cry
65rbdodge
jeff44044mag
Re: 318 is finally in, with issues...
« Reply #1 on: July 21, 2008, 07:23:35 AM »
the end bolts have water in them. front and back on each side. they should be where the studs were.
65 coronet 440/4 speed/9.75
71 dart custom 4 door 400/727/8.75
03 dakota 239/5 speed/8.25
Dono
Want what you have..........
« Reply #2 on: July 21, 2008, 07:41:15 AM »
Sure you don't mean exhaust studs?
loiq
« Reply #3 on: July 21, 2008, 10:12:14 AM »
agree
I was gonna say, no head bolts go into coolant passages on a 318.
bwells
« Reply #4 on: July 21, 2008, 01:02:45 PM »
 thank you  I'll play with it more tonight, and hopefully get some pics up.
bwells
« Reply #5 on: July 21, 2008, 01:04:07 PM »
When I pulled the exhaust off, there was only 1 stud.  Everything else had bolts.
