November 22, 2008, 02:30:02 PM
| | |-+  neutral safety switch
Author Topic: neutral safety switch  (Read 95 times)
lineloc
« on: July 22, 2008, 09:13:24 AM »
  i own a b&m pro stick shifter and must install a switch. it`s the b&m micro #80609. there doesn`t seem to be a place to install it. am i missing something here? does anyone have an idea about this thing? thank you
Long Island, NY
Re: neutral safety switch
« Reply #1 on: July 22, 2008, 09:22:54 AM »
I'm rackin' my brain trying to remember how I did a B&M Streetstick installation in an old Trans Am I used to have.  I wasn't impressed with the microswitch's location and I somehow grafted the factory one to operate off the B&M shifter.  If it comes to me, I'll post it.
« Reply #2 on: July 22, 2008, 10:28:28 AM »
The factory nuetral safety switch is in the transmission. The shifter you use should not interfere with using the original, unless I'm missing something...........
Long Island, NY
« Reply #3 on: July 22, 2008, 10:53:08 AM »
If the switch is in the trans, you shouldn't need the aftermarket one.
my64dart
« Reply #4 on: July 22, 2008, 11:19:21 AM »
Hi,
   I agree, you should use the neutral saftey switch thats in the transmission. The micro switch that B&M uses is a flimsy setup that might cause you problems. But if you need to hook it up, my switch was bolted on the passenger side of the shifter towards the rear. The switch is laying sideways on a metal plate with 2 small screws going vertical through the switch & plate. If you need a picture, I could email it to you. I can't figure out how to post pics on here.
       Jim
