November 22, 2008, 02:26:03 PM
| | |-+  400 balancer has 3 marks?
Author Topic: 400 balancer has 3 marks?  (Read 99 times)
z1bigtom
« on: July 23, 2008, 01:15:01 PM »
My 78 D200 has a 400 and i havent messed with the timing yet. Went and saw 3 marks on the balancer...1 notch goes all the way across, and the other 2 go half way across ..??
I'm assuming the full notch is what i'm gonna use? The half notches are on either side say 3" away from larger notch...
That One Guy
An American from America
Re: 400 balancer has 3 marks?
« Reply #1 on: July 23, 2008, 03:19:15 PM »
the other notches are for a certain degree of timing either way, but I can't remember what right off
"I'm your Huckelberry"
dusterdarryl
« Reply #2 on: July 23, 2008, 05:11:09 PM »
Iv got a cast crank 440 here with 4 notches on the balancer, & back in the early 90s I had another 440 that was the same
z1bigtom
« Reply #3 on: July 23, 2008, 09:31:47 PM »
So which do i use?
chryco
« Reply #4 on: July 23, 2008, 09:45:55 PM »
Set the engine to TDC using piston height, the distributor and valve orientation, install the damper, and mark the corresponding slot as indicated by your timing cover mark as TDC.
  Works for me !
    Chryco Wink
Hemi Darts Rule !!!!!
