November 22, 2008, 02:15:30 PM
| | |-+  Torsion bar set ups
Author Topic: Torsion bar set ups  (Read 413 times)
rapom
Torsion bar set ups
« on: July 24, 2008, 01:07:58 AM »
Has anyone really counted the # of turns they gave each Torsion bar bolt to get the front stance where they wanted it. Just courious, my dart is a 340 car with the 383 bars in it for anti dive in the harder turns. Once each bolt started in the threads, I marked the bolt heads and turned each one 24 turns. It sits level on both sides, but would like to crank it up a bit more. Just wondering where you all have set yours. Thanks duster
chryco
Re: Torsion bar set ups
« Reply #1 on: July 24, 2008, 07:11:02 PM »
Keep crankin' them up. Don`t forget to give the front end a bounce before checking .
   Chryco Wink
Hemi Darts Rule !!!!!
coors00
« Reply #2 on: July 24, 2008, 08:03:42 PM »
Measure from the floor to bottom of ball joint and bottom of lower control arm@ torsion bar adjuster.
Make sure both sides are the same after raising.
And like he said, stand on the front bumper and jump up and down before measuring.
guzzimike
1968 Dart GT (383)
« Reply #3 on: July 25, 2008, 12:08:54 AM »
68 Dart, .920 Torsion bars, 383 engine.
Set at 11 turns.
doug 371
« Reply #4 on: July 25, 2008, 07:36:13 AM »
it depends wether u put them in with or with out the upper rebound bumper
ValiantOne
Western MD
« Reply #5 on: July 25, 2008, 02:51:04 PM »
I had my camber get all screwed up by raising the front end up too much with the t-bar adjusters.
Anyone else?
CE
Chris Evrard
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
« Reply #6 on: July 27, 2008, 11:38:06 PM »
  With the 6 cyl bars in the RR it put the top of the adjusting nut about 1/2" up inside the LCA. With the OEM bars it was about flush with the bottom of the LCA. The Dart has .890 bars with a SB and the adjusting bolt face is about the thickness of the head of the bolt out of the LCA.
  After adjusting, I've found the bounce method to be a bit unreliable. After I drove the car it settled even more so now I just drive them around the block and recheck it from there.
MoPar_or _NoCar
« Reply #7 on: July 28, 2008, 12:22:37 AM »
Anyone else?
CE
Mine went out of whack as well with the SB.
blasphemous
« Reply #8 on: July 30, 2008, 05:52:44 AM »
I haven't adjusted the Scamp, but my Mazda pickup is the same way.  I have to drive around the block to really settle in the adjustment.
