Topic: 5 point harness (Read 176 times)
digler
DRIVE LIKE LIGHTNING CRASH LIKE THUNDER!!!!
anyone have pics on how they installed their safety harness to the vehicle , on the cage & floor or any other way thanks
That One Guy
no pics, but we just put a tab on the bars and bolted them to it, the crotch and sides are just boldte to the floor, I'm sure someone will get you a pic of what they've got
"I'm your Huckelberry"
west
i welded in a bung.  then just put a bolt through to attatch  i made these for the lap belt so i could use the stock threaded holes in the floor i can also still use the stock belts at the same time if wanted
The 5th point ("anti-submarine" belt) usually gets attached to the seat's mounting bracketry when a frame is constructed for the seat and attached to the subframes on each end. A bolt through the floor with a 3" square plate reinforcing it works too. Don't just use fender washers on this instead of a welded in plate; your life might depend on it.
