December 04, 2008, 09:37:15 PM
| | |-+  Pinion angle???
Author Topic: Pinion angle???  (Read 346 times)
magart
Cape Breton, Nova Scotia
Pinion angle???
« on: July 31, 2008, 08:47:09 AM »
I just installed my A-body  8 3/4 into my duster. It's an original A-body part, and I installed it on her own stock springs-basically the way it came out.
Question: do I need to worry about pinion angle at this point. This is more of a dry fit than anything because the springs will have to be swapped eventually anyway, but the car will see the road and track possibly the way it is.....ps-there were no shims or wedges in the assembly
Long Island, NY
Re: Pinion angle???
« Reply #1 on: July 31, 2008, 08:52:53 AM »
You'll be fine, but wouldn't you want to check it anyway?
magart
Re: Pinion angle???
« Reply #2 on: July 31, 2008, 08:58:03 AM »
I will. I just dont have the parts to change it
coors00
Re: Pinion angle???
« Reply #3 on: July 31, 2008, 07:05:33 PM »
It worked from the factory, it will be ok
75Dart440
Re: Pinion angle???
« Reply #4 on: July 31, 2008, 09:46:43 PM »
It depends on how hard your car launches and whether it hooks on launch, auto versus manual trans.......all of these factors will affect how much the front segment of the rear spring wraps up, thus raising the pinion on the diff.  Make sure you are using a pinion snubber on it though.  Without a pinion snubber you could break a u-joint if the pinion comes up far enough.
I'm running adj. pinion snubber, auto trans, and BFG street tires, so hooking isn't an issue with my car.  It just burns the baloneys!!   4 speed
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
496dart
Re: Pinion angle???
« Reply #5 on: August 04, 2008, 12:34:31 AM »
You wont need a snubber.
If you arent racing it at the track seriously with slicks , etc...  I  wouldnt worry about it.  I f  you do need to adjust it,  you can get shims from  Mancini.
