December 04, 2008, 12:56:39 PM
| | |-+  73 DART SWINGER WILL A B-BODY 8-3/4 FIT UNDER IT OK
Author Topic: 73 DART SWINGER WILL A B-BODY 8-3/4 FIT UNDER IT OK  (Read 512 times)
tedster
« on: August 03, 2008, 09:31:41 PM »
hi this is my first post and my name is Ted
I am putting a 440/727 in this dart and having a hard time finding an A-Body rearend,will a B-Body with the spring perches 44 center to center and hub to hub 59inches work ok with the right wheels,and if so what wheels do i need.or what is my best option i have a 3.55/489 case for it and am working on a 3.91,this is a 6cyl. car so i have a lot to do.can some one help me out please.........Ted
Re: 73 DART SWINGER WILL A B-BODY 8-3/4 FIT UNDER IT OK
« Reply #1 on: August 03, 2008, 11:17:10 PM »
Many people are running b-body rear ends, some haven't even moved the perches. Fortunately I have never had to resort to making a b-body rear fit so I can't answer the wheels question.
tedster
« Reply #2 on: August 04, 2008, 12:27:49 AM »
thanks jim
i have heard of people putting them under the darts but it would sure be nice to hear from someone that has done it,i got rid of all my mopar stuff in 1984 so its been along time for me since i have messed around with any mopars i need to get back on top of things.........Ted
loiq
« Reply #3 on: August 04, 2008, 09:45:25 AM »
I have an early B-Body rear ('63) under my Valiant. Of course, it also has the crappy old-style axles, but it's only about an inch wider than an A-body rear and it was $50 on craigslist. drinks
lake worth, florida
55robert@comcast.net
« Reply #4 on: August 04, 2008, 11:45:41 AM »
"B" dana 60, 9" wheel with 7" backspace.
tedster
« Reply #5 on: August 04, 2008, 03:56:54 PM »
thanks for the replys,the a body measurements i have are from 1965 to 72and there 44 ctc and 55.6 hth i will have to check out some older ones,thanks guys
67Dart34dr0
« Reply #6 on: August 04, 2008, 04:34:56 PM »
Is a '65 B-Body rear the old length that can most easily be used in a Dart?
1967 Dodge Dart 270 4-door
'72 340 (9.5:1), '72 727 Torqueflite, '72 8-3/4" Rear, '73-'76 Big Bolt Discs, Repaints, Original Interior, Possibly Original Miles, stock '72 valves, Factory A/C
evstraus
« Reply #7 on: August 04, 2008, 11:53:43 PM »
Any B Body axle from 1962 to 1970 will work. The later years had the non tapered axles which are a better option. The spring perches are only 1 inch wider that the A Body's.  You can spread the leaf spring 1/2 inch on each side and the axle housing will drop right in. With todays offset rim choices getting a nice set will be no problem.  Eric  4 speed
tedster
« Reply #8 on: August 05, 2008, 12:09:57 AM »
actually i already worked a deal out with a guy for the A-Body rear hub to hub with no center in it,it really would'nt be that big of a deal but i already told him i would take it a few days ago and he just called me back today so i am gonna keep my word on it that i would take it,and i still might pick the B-Body one up there is a big price difference in them and the B-Body one already has the 4.5 bolt pattern and the big drums on it,but can you still get the factory rally wheels to work on it with the B-Body rearend in it and still get enough meat on em to keep it from sitting in one spot spining the wheels off it
JWSewell
« Reply #9 on: August 05, 2008, 02:26:44 AM »
 I just put a 67 Charger 8 3/4 in my 74 Scamp. Just had to flex the springs out to line up the perches, (just me and my hands,very, very easy) The factory 14x5.5 rally wheels fit, (very close to outer fender trim, but they fit) Sorry no pics yet.  Embarrassed
 I am really considering getting some 17x8 Bullitt rims w/ 255/50R17's for mine.
JWSewell
« Reply #10 on: September 29, 2008, 01:16:18 AM »
 Pics of my 67 B-body 8 3/4 in my 74 Scamp.  Its 59 inches overall with 44 inch perches.
 I just flexed the leafs out bout 1/2 inch each and it bolted up fine.  I used all the stock brake parts, even the hard brake lines. (new shoes, W.C and hardware)
 The stock 14x5.5 ralley wheels fit back under with 235/60R14's but I will have to trim the fender lip to protect the sidewall. You can see in the tird pic that the inner side wall was rubbing the inner wheel well with the stock 7 1/4 rear axle.
 Soooooo,a 5.5 inch wide wheel with 3.75 backspacing will clear the fender lip with a FAT sidewall.  Add 2.5 inches in wheel width for a 8 inch wide wheel and increase Backspacing to 6.25 inches for a perfect fit.   I think!! \/][ ??
