December 01, 2008, 08:20:40 PM
| | |-+  Help? Wheel Tubs giving me fits!
Author Topic: Help? Wheel Tubs giving me fits!  (Read 1382 times)
mopowers
Re: Help? Wheel Tubs giving me fits!
« Reply #30 on: September 24, 2008, 11:14:15 PM »
Here's another that may help.
http://autoweldchassis.com/Instruct.ivnu
2006 Dakota
coors00
« Reply #31 on: September 25, 2008, 07:50:20 PM »
I used a set from S+W. I don't have any pics of them apart but did cut the car like you are showing. After your done you will need to make a support for the bottom of the rear window. I made mine go up from the back bars and then across the bottom inside. Since i chose to use the trunk hinges in the stock location i had to make little tubs in the tubs for them when the decklid is closed. When making tubs that will not fit in whole i cut them minus 1" off the widest part. Then put the tub in. You then measure every 2" from where you cut it off to the outside of the car and make a *filler* piece from what you cut off. This piece you pop rivet to the tub and then i use urethane to attach it to the quarter panel. Here is the only pic i have.
Could you expand on the rear window support? I didn't know about that.
bigtimeauto
Plymouth meeting, PA
« Reply #32 on: September 25, 2008, 09:01:03 PM »
Here is a pic, not a real good one but should be good enough to give you an idea:
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
Mopartist
« Reply #33 on: September 25, 2008, 10:41:53 PM »
Whoa! I never thought about that! Thanks man!
Mopartist
« Reply #34 on: September 26, 2008, 02:38:21 PM »
Hey COORS; I was wondering about your trunk floor. Have you found any disadvantages in having your fuel cell NOT in a sump? (Debating on making mine flat since it's already cut out) Also; is that just krinkle paint?
Mopartist
« Reply #35 on: September 26, 2008, 07:53:14 PM »
Just keeping up with the progress as i go in case anybody else is gonna do this.
coors00
« Reply #36 on: September 26, 2008, 09:23:59 PM »
Thanks, I never even thought about that.
bigtimeauto
« Reply #37 on: September 26, 2008, 09:27:04 PM »
I kinda tripped over it myself. When the body guy was putting on the new window trim clips he leaned on that and i saw it drop. Glad i caught it!
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
coors00
« Reply #38 on: September 27, 2008, 07:56:37 PM »
I left a hole in the flat trunk; Thought I would install cell 2/3 of the way down in it, in case I run tail pipes. It will still involve an enclosed box for the battery.
CudaDon65
« Reply #39 on: September 28, 2008, 06:54:37 AM »
Nice work..keep the pics coming.
Pages: 1 [2]  All Go Up Print
