Topic: Driveshaft Length (Read 197 times)
871Dart
I have a 71 Dart with a 383 a 727 and schumacher mounts.Anyone know what length driveshaft I need? Thanks,Gary
Online
Depends on what rearend you have AND if the engine is in the stock location. That's why I measure every car I build. Put the yoke all the way in the transmission and measure center-center on the u-joints WITH the weight of the car supported at the rear axle, NOT the body. Subtract 3/4" from that measurement and that's what you need.
496dart
definately measure to be sure ---- my shaft was 48.25" . 440/727/8.75
sportfury70
My 70 dart w 8.75 was 48" It could have been about 1/4 inch shorter though.
MoPar_or _NoCar
 68 2dr HT. 383/727/8.75 on 20/35 springs. 48.25"
871Dart
The car is on jack stands the 2 rear stands are under the rearend housing.Is it ok to measure like that.Just put in a 383 stroked to a 496.Only this driveshaft and steering column {cause i went to manual} and this thing should be ready to fire.Appreciate the advice guys
871Dart
Oh sry it is an 8.75 489 case.Thanks,Gary
Online
Yep, that's how to measure it....
496dart
 that should work-- but make the extra effort and grab a helper--- crawl under it with the car on the ground and confirm your measurement. Usually driveshaft shops will only make you ONE shaft---------If u screw up the measurement----you will have to buy ANOTHER shaft.....
