September 07, 2008, 05:34:02 AM
| | |-+  ignition wiring
Author Topic: ignition wiring  (Read 242 times)
motorhead446
ignition wiring
« on: March 09, 2006, 10:43:06 PM »
Is the ballast resistor taken out of the loop when wiring in an MSD 7Al ? Also, what is done with the second field wire? The MSD has it own coil and billet dist so it basically is a "system" within its self. Will the alternator function properly with only one field wire?
Ed
Phoenix, Az
Re: ignition wiring
« Reply #1 on: March 10, 2006, 01:19:35 AM »
One field wire is a switched (run) 12 volts.  Check out this simple diagram:
http://www.bigblockdart.com/techpages/dualfield.shtml
formerly VIN_VL29U
motorhead446
Re: ignition wiring
« Reply #2 on: March 10, 2006, 07:16:04 AM »
Thanks Ed, that clarifys it for me.
bulzie dart
Re: ignition wiring
« Reply #3 on: March 12, 2006, 04:41:12 AM »
MSD has all the wiring diagrams and manuals for all the components they manufacture that you can download and print right off of their  website, and they have a really good tech line that I have used and found to be very helpful
