December 02, 2008, 11:09:08 PM
| | |-+  what gear oil to use?
Author Topic: what gear oil to use?  (Read 96 times)
Arillious
BAM!
« on: August 29, 2008, 08:59:49 PM »
ive got a sure-grip in my gf's dart with 3.23 gears. whats a better gear oil to use? 80w-90 or 85w-145? i put in the 145 but the car is up on stands cause im still workin on it.... also what aditive do i put in the oil? do i have to put any in? i had to for my auburn diff in my chally, but what about the old sure-grips?
thanks if you can help Smiley
Gasoline runs through my veins at 400 miles per hour.
lake worth, florida
55robert@comcast.net
Re: what gear oil to use?
« Reply #1 on: August 29, 2008, 09:14:01 PM »
add the additive
abodyjoe
South Jersey...
abodyjoe
« Reply #2 on: August 29, 2008, 09:22:01 PM »
use the additive.   i got it from the local ford dealer last time i needed it.
Arillious
BAM!
« Reply #3 on: August 29, 2008, 11:06:46 PM »
lol what aditive? the same aditive that i used with my auburn dif?? am i good on still using the 145??? lol
Allentown, PA
« Reply #4 on: August 30, 2008, 08:18:44 AM »
the 145 will be fine .... you need to ask for limited slip additive when you go to the dealer .... ether Mopar brand or Ford brand will work fine ..
Arillious
BAM!
« Reply #5 on: August 30, 2008, 12:39:25 PM »
thanks guys what do the numbers mean just out of curiosity?
Allentown, PA
« Reply #6 on: August 30, 2008, 12:41:24 PM »
the nubers are the weight or the viscosity of the oil ... the higher the number the thicker the oil ....
Arillious
BAM!
« Reply #7 on: August 30, 2008, 08:49:28 PM »
which number determins the viscosity?
85w-145
and whats the other number for?
Allentown, PA
« Reply #8 on: August 30, 2008, 11:00:38 PM »
they are both viscosity #s .. one higher one is the cold viscosity # and the lower is the operating temperature viscosity ...
