Topic: Master Cylinder pre load query (Read 136 times)
VF Coupe
I was wondering when putting a master cylinder onto a brake booster, do you set the booster plunger so that there is some pre load on the master cylinder as it is bolted on? ie bosoter plunger comes into contact with the master cylinder just before the retaining bolts are fully done up.
Thanks!
"She sips nitro...with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the bitch is born to run! " Mad Max!!!
69DartW250
There is a spec listed in the service manual that shows the distance the rod should protrude from the mounting surface of the booster/master interface.
George
1990 Dodge W250 4X4, 4 speed 1969 Dodge Dart Swinger 340, auto 727
VF Coupe
Sorry, dont have a manual.
It is for 69 A Body with booster!
Thanks!
william
No preload, if there is the brakes will drag.
