November 22, 2008, 07:57:12 AM
|-+  General Category
| |-+  Off-Topic
| | |-+  the 727
Author Topic: the 727  (Read 301 times)
mopardart71
the 727
« on: September 11, 2008, 02:18:12 AM »
i have a stupid question whats the difference between a 2wd trand and a 4x4 trans can you take of the rear of the 2wd and attach transfer case or is it way differant i havent had much time to get under my truck and look thanks will.oh its a 75 power wagon small block auto
oldkimmer
Re: the 727
« Reply #1 on: September 11, 2008, 03:01:23 AM »
........................The 4x4 trans has an adapter bolted to the rear of the case and a short tail shaft........u would have to remove all the internals to change out the car trans tail shaft,then put in ur 4x4 tail shaft, or put the internals from the car trans into ur 4x4 tranny....kim.........
mopardart71
Re: the 727
« Reply #2 on: September 11, 2008, 08:28:11 PM »
is $250 a good deal for labor to rebuild the transmission i supply the rebuild kit .
motorhead446
Re: the 727
« Reply #3 on: September 11, 2008, 10:47:49 PM »
If the guy/gal knows what they are doing, thats a fair price.
oldkimmer
Re: the 727
« Reply #4 on: September 12, 2008, 12:39:38 AM »
agree..................................kim..............
dangerdawg
Re: the 727
« Reply #5 on: September 12, 2008, 10:01:28 AM »
i had a 74 power wagon, once upon a time.
68fish
Re: the 727
« Reply #6 on: September 12, 2008, 11:53:16 AM »
Sounds good to me. I just got quoted $450.00-$500.00 (reputable shop) for a complete overhaul with high performance clutches steels and so forth.
mopardart71
Re: the 727
« Reply #7 on: September 13, 2008, 01:37:34 AM »
ok now its 800 pull rebuild and install w new converter
496dart
Re: the 727
« Reply #8 on: September 13, 2008, 03:20:22 AM »
what  Kimmer said-----------the truck one is different and has a short tail section--
dont bother with one---get one out of a car
i  went thru  this deal  a couple years ago
