December 03, 2008, 01:59:42 AM
| | |-+  POR-15
Author Topic: POR-15  (Read 659 times)
69-DART
POR-15
« on: September 17, 2008, 05:27:42 PM »
JUST HAD THE DART MEDIA BLASTED. ROLLED OVER AND OVER ON THE ROTISERRIE BLEW OUT AND VACUMED
BEFORE DOING ANY WORK OF THE BODY WORK ON THE CAR.. SHOULD THIS THING BE SANDED, WIPED OR WHAT?
1ST I WAS GONNA DO ALL OF THE METAL WORK....QUARTES FENDERS ECT.
AFTER DOING THE WELDING/GRINDING I WAS GONNA JUST SHOOT THE WHOLE THING INSIDE AND OUT WITH AN EPOXY-PRIMER
SO, MY QUESTION IS: WILL THE EPOXY COATING SERV AND DO THE JOB OF SEALING LIKE POR OR DO I NEED TO POR-15 THE INERS AND THEN EPOXY EVERYTHING?
Allentown, PA
Re: POR-15
« Reply #1 on: September 17, 2008, 05:42:08 PM »
Por 15 is for use over rust ... if you had it blasted you do not need it.   Do all your welding and work then use some "prep solve" to wipe the whole car down, then shoot it with etching primer, then a coat of epoxy primer.  The epoxy primer is a great sealer.
Could you also turn the caps lock off ... make the posts hard to read .. thanks !!!
69-DART
Re: POR-15
« Reply #2 on: September 17, 2008, 06:01:53 PM »
should i do a quik once over of the whole car with say ...120 or 180 grit just to knock down/off what feels like loose ruff material that is now on the car?
Allentown, PA
Re: POR-15
« Reply #3 on: September 17, 2008, 06:09:06 PM »
you can if you want but the prep solve will do most of the cleaning ... wipe it on with a paper towel and blow it dry with compressed air as you complete each section.  it will help with the dust as well ...
I am doing the same thing as you   http://www.bigblockdart.com/index.php/topic,30650.0.html
69-DART
Re: POR-15
« Reply #4 on: September 17, 2008, 06:20:10 PM »
so order of opps should be.. let me know what I'm missing or added un-necessary
-180 ruff sand
-blow off
-metal work
-prep solve
-wipe and blow off
-metal etch primer ( all surfaces that will be painted, inside and out?)
-epoxy primer (inside and out)
-then body filler
-sand
-dust with rattle can
-sand for highs and lows
-fill and sand again
-shoot high build primer
-finish sand (wet or dry?)
-shoot
Allentown, PA
Re: POR-15
« Reply #5 on: September 17, 2008, 06:25:57 PM »
yup ... except the body filler needs to go on bare metal with 80 grit or courser scratches so you'll either have to grind your primer off or do the filler work before any priming
69-DART
Re: POR-15
« Reply #6 on: September 17, 2008, 06:30:58 PM »
really... i thought that the bondo could go right over the epoxy primer?
Allentown, PA
Re: POR-15
« Reply #7 on: September 17, 2008, 06:34:30 PM »
nope ... filler goes on steel ... if you need more filer once you start priming then use some 2 part polyester finishing putty, it is designed to be used over primer.  comes in pints and quarts and uses the same activator as regular filler .... btw get a good lightweight filler like "rage Gold"  etc not bondo from walmart
69-DART
Re: POR-15
« Reply #8 on: September 17, 2008, 06:39:19 PM »
cool thanks for the advice
so it would probably be fine to initaily hit the whole car with th 80 grit right off the bat insdtead of the 120-180 i had in mind?
also what about the coat of metal etch...whole car, inside and out?
Allentown, PA
Re: POR-15
« Reply #9 on: September 17, 2008, 06:41:39 PM »
most manufactures say that if you have a spot of bare metal bigger than a basket ball then you will need metal etching primer.  So yes all the bare metal gets it ...
BTW welcome to the site
got any pics ?   we love pics on this site
69-DART
Re: POR-15
« Reply #10 on: September 17, 2008, 06:45:09 PM »
10-4
so, like stuff the gun inside of the door and quarter shells and pull the trigger..?
i'll probably ruff cut the quaters and hit those with epoxy while they are exposed before putting the skin over it and cutting it in
sound good?
as for the pics...you got it.
i'll be tossing em up with every step of progress
so far just built the rotisserie and got it stripped and blasted. will post some pics of that
69-DART
Re: POR-15
« Reply #11 on: September 17, 2008, 06:48:52 PM »
and what about useing the 80 grit right off of the bat?
Allentown, PA
Re: POR-15
« Reply #12 on: September 17, 2008, 06:49:06 PM »
You blasted the insides of the doors ?   I hope you/they did it with plastic media blast ... I would pour some activated primer in there and roll the door around until it was all coated ... I think spraying would be futile ...
Allentown, PA
Re: POR-15
« Reply #13 on: September 17, 2008, 06:51:06 PM »
80 grit scratches will be difficult to sand out of the car so where they are not needed so the 180 would probably be best for the whole car ... save the 80 grit for the filler areas only, 36 grit would actually be better ....
69-DART
Re: POR-15
« Reply #14 on: September 17, 2008, 06:53:32 PM »
the guy i took it to blasted pretty much everything that the wand would reach
69-DART
Re: POR-15
« Reply #15 on: September 17, 2008, 10:53:43 PM »
SO YOU ARE SAYING 80 OR 36 GRIT ON THE FILLER ONLY?
150 OR SO ON ALL THE BARE METAL...WONT THE 36 OR 80 GRIT SCRATCH UP THE BARE METAL AROUND THE SPOT OF FILLER WHEN SANDING
Allentown, PA
Re: POR-15
« Reply #16 on: September 17, 2008, 11:47:10 PM »
yes but it won't be the whole car with 80 grit scratches just an area around the filer ....
69-DART
Re: POR-15
« Reply #17 on: September 17, 2008, 11:59:59 PM »
RIGHT ON.
NOW WHAT IS "ACTIVATED PRIMER"?
WILL THIS ALSO TAKE CARE OF THE NEW SEAM AT THE BOTTOM OF THE PANELS?
OR SHOULD I STILL USE SOME OF THATWELD THROUGH SPRAY ON STUFF ON THE SEAMS BEFORE SPOT WELDING THE SEAMS
Allentown, PA
Re: POR-15
« Reply #18 on: September 18, 2008, 12:09:44 AM »
activated primer is primer that has the hardener mixed into it and is ready to spray  or in the case of etching primer the acid has been mixed in ...
weld through primer is a pain in the ass ... it causes spatter and poor weld quality ... I only use it where there is no chance of coating the panel from the both sides .... did I mention I hate the stuff ?
69-DART
Re: POR-15
« Reply #19 on: September 18, 2008, 12:16:21 AM »
SO WHILE THE PANEL IS OFF AFTER THE RUFF CUT I'LL CLEAN AND COAT THE INNER STRUCTURE WITH EPOXT PRIMER(OR SHOULD I USE METAL ETCH HERE TOO?)
AFTER THAT...WELD UP THE NEW PANEL, INCLUDING SPOTTING THE WHEEL WELL LIP.
MIX UP SOME OF THIS STUFF AND POOR IT FROM THE INSIDE ALONG THE BOTTOM OF THE PANEL...AND INSIDE OF THE DOOR SHELL
Allentown, PA
Re: POR-15
« Reply #20 on: September 18, 2008, 12:18:42 AM »
yup ... if it is bare steel etch primer then weld and coat with epoxy .... but do me a favor before you do anything on the car got out to the garage and get a screw driver and pry the caps lock key off of your keyboard   LOL LOL LOL LOL .... Thanks !!!
69-DART
Re: POR-15
« Reply #21 on: September 18, 2008, 12:25:54 AM »
you mean, 1-metal etch primer 2-epoxy and then weld the panel?
Allentown, PA
Re: POR-15
« Reply #22 on: September 18, 2008, 12:27:20 AM »
cut the panel out ... spray the metal etch then weld and cover the weld with epoxy primer.
MoPar_or _NoCar
Re: POR-15
« Reply #23 on: September 18, 2008, 12:28:00 AM »
 lol
69-DART
Re: POR-15
« Reply #24 on: September 18, 2008, 12:40:19 AM »
think i'm lost..sorry.
i was talking about treating the inner structure before capping it off with the skin
Allentown, PA
Re: POR-15
« Reply #25 on: September 18, 2008, 12:47:50 AM »
no problem ... ask any questions you may have ... that is what the board is for  bbd sign
The inners can be painted with etch then weld the skins on and either pour or spray the epoxy in the welded area ...
69-DART
Re: POR-15
« Reply #26 on: September 18, 2008, 12:59:12 AM »
i was considering shooting epoxy on the inner structure after cleaning while the panel was off..not good idea?
i guess the part that is confussing me is the metal etch?
are suggesting to metal etch prime the entire car inside and out before coating with the epoxy inside and out?
Arillious
BAM!
Re: POR-15
« Reply #27 on: September 20, 2008, 03:19:56 AM »
this is a cool thread... learning allot
lol the caps lock is funny though lol
Gasoline runs through my veins at 400 miles per hour.
69-DART
Re: POR-15
« Reply #28 on: September 20, 2008, 10:26:22 PM »
 Dunno?
rjsjea
ProTouring Demon
Re: POR-15
« Reply #29 on: September 20, 2008, 11:00:41 PM »
Several epoxies are bare metal epoxies......ie RM DP90 from Glasurit.  Not to throw a monkey wrench into things as there are several ways of doing this.
Skip the weld thru primer.  Weld the quarter on (bare metal), clean the weld (smooth it with 36grit) and prime (either w/ an etch or Epoxy as stated above) on both sides.....you can get decent coverage inside the quarter.  Hit the epoxy with 100 grit or so paper and do your filler work.  Use a hi quality filler (Rage or similar) and it will stick to the bare metal and roughed epoxy primer.
Pages: [1] 2  All Go Up Print
