December 03, 2008, 02:05:12 AM
| | |-+  anyone use flaming river products?
Author Topic: anyone use flaming river products?  (Read 302 times)
v-man
« on: September 17, 2008, 08:06:10 PM »
How did you like their stuff. I may buy the steering box and column
68dodge
Re: anyone use flaming river products?
« Reply #1 on: September 17, 2008, 08:42:10 PM »
I have the steering coupler and it is a nice piece. Also built heavy.
abodyjoe
South Jersey...
abodyjoe
« Reply #2 on: September 17, 2008, 08:45:46 PM »
used a few couplers and always liked them.
crazy 340
« Reply #3 on: September 17, 2008, 08:53:38 PM »
installed there copler last winther nice parts and built strong  !nanr
10.48 full trim duster
dd69a
« Reply #4 on: September 17, 2008, 10:29:26 PM »
i have there manual rack on my alterk awesome piece.
VTI
NHRADART@msn.com
« Reply #5 on: September 17, 2008, 10:55:04 PM »
Used their copler. Like it.
4spdfury
« Reply #6 on: September 17, 2008, 11:12:35 PM »
we have their steering box and its areally nice piece.
evstraus
« Reply #7 on: September 18, 2008, 12:31:15 AM »
I bought there 16:1 steering box, all new not rebuilt. Eric  4 speed
Winter
« Reply #8 on: September 20, 2008, 02:16:06 PM »
I have the steering box and manual conversion kits for both the E-body and A-body. I like the way it works with the E' better because the steering column is spring loaded, so there is flexibility. On the A' the column is ridged and it relies on the slip pot to give flexibility, so when the kit is used there is no more give in the column, other than the shaft sliding with in or out of the U-joint coupler. Cut the shaft long as possible, still allowing for the U-joint to rotate, and collapse 5/8". I did not drill for the set screws either. I would have left the original A-body coupler if it was long enough. I was thinking after I should have got the extension instead. The FR steering box feels no tighter than the stock aluminum type on the other car, but I needed to go manual. Also the original power was very exact feeling with no play.
