Topic: MY HEADLIGHTS DONT WORK ??? (Read 586 times)
south tex mopar
Yikes, i hate messing with electrical stuff. This week i have been rewiring the duster. My problem right now is that the head lights worked at one time. Then they started to turn on sometimes now nothing. So im thinking about it being the headlight switch.Ii have the light for my tach connected with the headlight wiring, and the tach light works. Thanks guys.
did you check the dimmer switch ? push it once or twice with the headlight switch pulled on and see if anything changes ...
satellite65
 Seen that twice. And yes, it could also be the headlight switch. Disconnect the tach light wiring to rule it out as a possible cause.
south tex mopar
By the dimmer switch you mean, with the head light switch pulled all the way out, i woild have to turn the knob right to left. Thats how the dimmer is on my duster. The inside lights dim when i do this. Also the heads lights worked long after i installed the tach.
MoPar_or _NoCar
Check your ground wires on the radiator brace. Did you clean the paint off?
no the switch for the high beams or low beams the one on the floor ....
south tex mopar
Oh shit you think that could be it?? Ill really feel dumb if your right. Im going outside to check. Be right back.
south tex mopar
OK so that didnt work, but another thing worth mentioning is that i had payed someone to connect my electric fuel pump to the ignition, like the instuctions said to do. I bought the holley blue one and i bought the wiring kit for it. Well i just noticed that when i have the car off and pull the headlight swith to the on position, the pump turns on.
MoPar_or _NoCar
south tex mopar
My tail lights work and rear turn signals, my front lights and signals dont.
south tex mopar
Yes i did
you are going to have to figure out what the other guy did, and undo it so the headlights work .... then find a spot to hook the fuel pump to. if you have a test light you will be ableto see what fuses are live with the key on and you can tap power for the fuel pump from there.
satellite65
Do you have the wiring diagram for your car. It's going to help you TREMENDOUSLY. Without it, you're just kinda pokin' around in the dark unless you really know the electrical system like the back of your hand.
Don't let wiring/electrical stuff intimidate you. It's really no big deal once you break it down into little pieces. Your biggest problem right now is UNDOING all the F-ups that were done by others. Good luck, we're here for ya.
south tex mopar
Is there an easier way? Like, just connect the positive of the pump to the positive on the ignition swith?
south tex mopar
Yeah i have been having a blast fixing all this crap in my electric system. Man, oh man, its just swell. so i dont know if you guys remember, a few months back that my first post was about my engine not reving past 3000 rpm. Turned out to be ingition box. So i went thru all my wiring in my ignition system,and found a couple problems, that i also fixed. Now just have to fix this problem and it should be good
south tex mopar
Thanks man
satellite65
Yes, to the "run" position. I'd power the pump through a relay though. I don't know how much current the ign. switch is rated for or how much current the pump draws.
south tex mopar
Yes, the relay came with the wiring kit from holley
MoPar_or _NoCar
If I was you, I would get a aftermarket fusebox and pull switched power to it. It would be better to use a toggle than ign. switch. Then feed pump, fan, choke and other accessories from it. True value hardware stores have a cool 1 that uses 6 blade fuses. You want to keep any extra loads away from stock voltage limiter and ampmeter. Good luck.
signet
try wiggling the bulkhead disconnect plugs.
anyways too much load on the headlamp circuit soon cooks this connection.
south tex mopar
I disconnected the pump and disconnected the tach, trying for the head lights to work with both disconnected. Still not working. I then reconnected the fuel pump, this time to the acc port on the fuse box. reconnected the tach and called it a day. I just dont know what to think. Ill take a look at the bulkhead tomorrow. If yall can think of anything else i could try 2morrow let me know. Thanks guys
south tex mopar
ok so i removed all the wiring off a 73 duster 2day. Going to use anything i need. Also got the light switch. do you guys think maybe a relay could be the problem?
Once you figure out the correct way to make your lights work, install a relay for your lights as well. They'll be brighter than they've ever been and your switch will last forever. Check out http://www.danielsternlighting.com/ It's a wealth of information about getting the most from your headlights.
south tex mopar
Man i hate this crap. The bulkheads fine, still dont know. I really hate wiring
satellite65
There's no relay in the stock wiring. you need to get the wiring diagram for your car (internet download?) and trace the circuit with a voltmeter from the power source, through the switches (the one on the dashboard AND the floor switch for the brights) and out to the headlamps. if you just bounce around trying this and trying that you're going to rip all the hair out of your head.
First and foremost, you need a digital multimeter. Once you start probing and learning where power is and isn't, this becomes very simple.
