December 03, 2008, 02:17:40 AM
| | |-+  ProParts and plug wires- What are others using?
Author Topic: ProParts and plug wires- What are others using?  (Read 350 times)
cu440da
Saint Paul, MN
« on: September 18, 2008, 11:20:42 PM »
I seem to be burning through a couple sets a year. High temp boots just buy me a little extra time. Any one else have good luck with any particular brand/type?
'67 Notchback- 12.85 @ 109mph
PA Dart Guy
68 Valiant getting a 440 Heart Transplant
Re: ProParts and plug wires- What are others using?
« Reply #1 on: September 18, 2008, 11:33:06 PM »
Have you tried wrapping the plug wires with something? Header wrap on them might work...
MoPar_or _NoCar
« Reply #2 on: September 18, 2008, 11:59:37 PM »
I like MSD Streetfire wires. Never had an issue.
signet
« Reply #3 on: September 19, 2008, 12:18:21 AM »
fenderwell headers  Evil
abodyjoe
South Jersey...
abodyjoe
« Reply #4 on: September 19, 2008, 04:10:03 AM »
i used moroso and nver had a problem.  how do you have them run?
cu440da
Saint Paul, MN
« Reply #5 on: September 19, 2008, 09:58:58 PM »
The best way I figured to route them was to go under the headers. They are away from the heat, the real problem comes from 2 cylinders burning through the boots. I have the Taylor braided fiberglass protectors over them, but they are so close they eventually burn through. I've looked at the Jacobs ceramic boot wires but I'm not sure I'm ready to pay $200+ for spark plug wires.
Thin White Duke
« Reply #6 on: September 19, 2008, 10:32:13 PM »
I would use a real high temp sleeve.  They sell them through Jeg's etc.  How many sets have you bought?  Do they equal 200 yet?
guzzimike
1968 Dart GT (383)
« Reply #7 on: September 21, 2008, 12:11:21 PM »
 agree
« Reply #8 on: September 21, 2008, 11:39:08 PM »
I use MSD's 8.5mm  wires w/straight bendable ends w/ high temp boot socks as required. a couple spots needed 90 ends but thats easy enough to do.
RM440
« Reply #9 on: September 22, 2008, 12:28:50 AM »
 boom[]If you decide to replace your headers and you want to get rid of them, let me know.
540Valiant
« Reply #10 on: October 09, 2008, 05:53:55 PM »
I've run the same as PUREGTS and have no problems
speedymopars
Fighting illegal immigration since 1492!ProudSioux
« Reply #11 on: October 10, 2008, 01:11:15 PM »
On the van I had a problem burning through boots on #6.
I found that my MSD 8.5 mm with the "good" 90 degree boots were too thick and got it too close to the header, causing a burn through.
I took a set of cheapy wires with a thin as all hell 90 degree boot and used that boot instead. No more problems. The extra 1-2 mm of air gap completely solved the problem. In that case the thicker boot made the problem worse.
