December 02, 2008, 08:09:58 AM
| | |-+  Ram Overcharging !!!!
Author Topic: Ram Overcharging !!!!  (Read 295 times)
chryco
« on: September 19, 2008, 10:59:51 PM »
Help !
I took my 85' W250 360 / auto 4x4 out to get my trailer tonight and noticed my charge guage was way over on the charge side. When I got there , I noticed the battery was overheated . I checked the voltage across the battery and it was as high as 17 volts ! I pulled the field wire and headed home (without the trailer )and tried another couple of regulators , no change . I also found the center wire connector on the voltage reg  connector was screwed , replaced it too , no difference . Guess it`s my 105 Amp alternator ? Anybody have this happen ?
  Chryco Wink
cu440da
Saint Paul, MN
Re: Ram Overcharging !!!!
« Reply #1 on: September 19, 2008, 11:29:11 PM »
Do the 85's still use the ammeter? I had an ammeter go bad on me that acted like what you described.
'67 Notchback- 12.85 @ 109mph
chryco
« Reply #2 on: September 20, 2008, 08:10:12 AM »
It does have an ammeter . But how would that boil the battery and cause the high output voltage?
doug 371
« Reply #3 on: September 20, 2008, 08:13:54 AM »
check to see if 1 of the field wires is somehow grounding on the alt case
chryco
« Reply #4 on: September 20, 2008, 09:14:26 AM »
OK , I had to pull the larger guage field wire off to get home without blowing the battery.
 I`ll check
   THX
    Chryco Wink
oldkimmer
« Reply #5 on: September 20, 2008, 10:57:43 AM »
........................... agree............kim........
MoPar_or _NoCar
« Reply #6 on: September 20, 2008, 01:12:10 PM »
17 is alot, maybe the battery was toast and the internal plates were warped and touched?
cu440da
Saint Paul, MN
« Reply #7 on: September 20, 2008, 06:38:04 PM »
Couldn't really tell you why, but it goes into a massive overcharge state. I had replaced every bit of the charging system trying to fix it, to no avail. Finally ran into an older mechanic that had heard of it. I never would have figured that a gauge would contribute to a problem like that.
chryco
« Reply #8 on: September 20, 2008, 06:57:07 PM »
OK ! I`m going to dig into that one tomorrow . I`ve got the mod sheet from MAD .
  I`ll keep ya possted . Sure hope that does it.
    THX
     Chryco Wink
chryco
« Reply #9 on: September 20, 2008, 06:58:26 PM »
It`s a fairly new Optima deep cycle battery I swiped out of the racecar . Hope it`s not pooched !
    Chryco Wink
sunsetdart
us4ever365@hotmail.com
« Reply #10 on: September 21, 2008, 07:01:15 AM »
sounds like the voltage regulator went.....had the same thing happen to me............hot battery and hi amp reading........changed regulator, fixed problem.
chryco
« Reply #11 on: September 21, 2008, 07:10:19 PM »
Got a new reg today , not that !
chryco
« Reply #12 on: September 22, 2008, 06:47:18 PM »
Bought a new alternator today , BINGO ! All`s well . Never had one go super nova like that before .
   Chryco Wink
75Dart440
« Reply #13 on: September 28, 2008, 10:39:20 AM »
Yep....sounds like one of the field terminals went to ground in the alternator.
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
