December 02, 2008, 08:12:10 AM
| | |-+  disc brake swap 69 drum to 75 disc questions
Author Topic: disc brake swap 69 drum to 75 disc questions  (Read 166 times)
Megajoltman
« on: September 21, 2008, 02:01:06 AM »
Can I use my drum brake lower control arm and install the bigger ball joints?
Is the lower ball joint pressed in on the drum arm?
How do I remove/replace the 75 dart and 69 dart ball joints (press in/out or screw)
Thanks roger
building a 69 383 dart
Daily Driver 1998 Ram CTD 12V 4x4 Quad Cab Auto Shortbox, 3in Carli lift with custom rear lift springs (no factory blocks anymore) DSS Steering Stabilizer, 315 Toyo Open Country M/T tires
Re: disc brake swap 69 drum to 75 disc questions
« Reply #1 on: September 21, 2008, 02:45:38 AM »
Lower balljoints are spindle specific. The hole in the LCA is the same on all arms. It's the upper ball joint that is different and requires a different control arm.
Megajoltman
« Reply #2 on: September 21, 2008, 03:00:30 AM »
Thanks
« Reply #3 on: September 21, 2008, 10:33:10 PM »
Yes.
NO! Only trucks' lower ball joints are pressed into the LCA. CAR lowers are BOLTED to the steering knuckle. They look alot alike and sometimes get passed off as 73ish disc brake set ups at swap meets.
Upper ball joints screw out/in (truck and car)
Lower ball joints press in ON TRUCKS.
CAR lower ball joints bolt on to teh steering knuckle
