Topic: Neutral safety switch question. (Read 124 times)
Thin White Duke
The three prong plug that goes onto the 727 drivers side has 3 wires. One is brown and I believe went to the starter relay. I took out the factory relay and put a Ford relay under the dash. Do I need to connect the brown wire to the ford relay? Just trying to make sure it starts.
the brown wire is the ground to the coil in the relay, if you don't connect it you will be able to start it in gear. not good.
