Topic: Line Lock/Master Cyclinder (Read 704 times)
CA Duster 383
My 74 Duster 383 with Hooker Supercomp fenderwell 1-7/8" headers is ready for the new M/C and the line lock.
My headers run right under the M/C and it is necessary to pull the M/C to remove the left header.
I have the 2 bolt heat shield for under the late model M/C and I want to mount the line lock to the left on the firewall.
So my question is....must I use hard lines to connect the two or can I have S/S flex lines made up for this??
Open to all comments and opinions.
you can go either way but you can also purchase the ss lines already made.
tubtar
This was during mock up , but it is legal and works. A heat shield would be good , I jacket the lines where they run from m.c. to proportioning valve. Earl's has them pre made.
It's a fine line between " how much ? " and " Why the hell not ? "
CA Duster 383
Tubtar,
Thank you for the photo, that is what I have been looking for, now I can order some lines or have them made up.
Capt Jack
ok, so...just so I understand...I thought the line lock was supposed to be AFTER the proportioning valve.
admittedly, most locks Ive seen are not, but every 'written instruction' I can find says place it after.
tubtar
An adjustable valve can be on either side I would imagine , since it is just limiting pressure to one end of the car ........maybe I should have read the instructions ?  It seems to work fine.........did on my last car too. Good point though........... I just copied what I saw with other cars.
nasty68
My last car the line lock was right after the master and before the proportioning valve and never had any problems with it at all. This car i have no valve in the front brake system, just the rear brakes has it.
68 dart, 383, 727 97 wrangler sport, 4.0
Capt Jack
kewl. I'll give it a shot that way.....I mean, what have I got to lose, right? theyre just brakes
CA Duster 383
The proportioning valve has to do with front to back balance of the braking function.
A line lock has to do with locking either the front or rear brakes when doing a burn out.
I have always seen line locks plumbed at the M/C, not down line after the proportioning valve.
coors00
I agree, between the m/c and valve; at least that's what all the instructions(that work) say.
oldkimmer
...........Read the NHRA rule book..............kim........
A13Dart
What's your take on the rulebook Kim ?
Capt Jack
this is what I found: BRAKES & SUSPENSION: 3
3.1 BRAKES ......If brake system includes a differential pressure switch, line-lock installed on front brakes must have solenoid installed after the differential switch. All line-locks (electric or hydraulic) must be self returning to normal brake operating mode. so, if I read this right, its 'after' the proportioning valve ie: "differential switch"?
coors00
Kim's right; I thought mine was between, but just looked, and it is after the valve.\ But after reading the link Capt Jack put up- I think, depending on the year; some valves are not "differential", only shut off the leaky end.
Capt Jack
I think youre right. the coronet has a single res MC...both sets of locks plumb right off the MC and theres no valving system
coors00
Another argument at tech inspection...On a70, I installed it after, but thought I had installed it between, and have been saying between. sigh. old age.
A13Dart
I sent an email to the NHRA technical department about a year ago regarding general regulations 3:1 line lock installation:
Hi Jim,
Can I install the line lock solenoid between the master cylinder and the factory distribution block on my 68 Dodge Dart? I would prefer to leave the factory front brake lines and fittings intact as much as possible. General regulation 3:1 refers to a pressure differential switch. I am not sure if this applies to my application.
Thanks,
Mike.
Hi Mike,
Does the 68 use a dual reservoir master cylinder? Can’t remember when they switched. If so, yes, you can put it between the master and block, on the front brakes. Conversely, if you have just a single reservoir master, you’ll have no choice but to replumb the front brakes for the line-loc; otherwise you’d have a four-wheel line loc. Let me know it that helps.
Jim
coors00
That nhra answer muddied the waters.
Capt Jack
oh wow. well at least that explains how so many with it plumbed that way get through tech. in my case that would really make life a lot easier being able to do it between the MC and the block....thanks a ton for that!
