December 04, 2008, 07:00:19 PM
| | |-+  how to run bit faster??
Author Topic: how to run bit faster??  (Read 449 times)
1971scamp383
Rouyn-Noranda,Quebec
« on: September 25, 2008, 11:07:52 PM »
hi guys....i have a BIG 1968 monaco 500(4400 with me in it) with a 383....i have 3.91 locker rear  and 26's tires.....the engine is not stock but its not a top fuel monster neither.....need to adjust the carb and need a new fuel pump...the trans is rebuilt with a transkit from b&m and a 2500 torque stall....but ive tried it at the track......on the 1/8 mile my best run is 9.49 ....and like 2.28 best 60'..not bad for a 4400 pound whale.....but...what can i do to go down a bit....my plan is to run about 9.00 - 9.10....a bit closer to the sportsman categorie....im planning to put a manual valve body...holley blue pump....and a 4.30 rear gear...to help the ''out of the box'' thing....what do you guys think about that???
on the build....1971 plymouth scamp 383...
grudd440
Re: how to run bit faster??
« Reply #1 on: September 26, 2008, 12:31:58 AM »
A 1 inch 4 hole carb spacer might help.
440 DusterDemon
The 1
« Reply #2 on: September 26, 2008, 12:41:27 AM »
Take some weight out and what kind of 26"tire,and fix the carb and fuel pump!
" I'm ready to kick the tires and light the fires Big Daddy!!"
Go Phillies!
« Reply #3 on: September 26, 2008, 12:44:32 AM »
go on a diet
« Reply #4 on: September 26, 2008, 06:47:50 AM »
Take out about 300-400 lbs of weight would be the cheap way!!
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
« Reply #5 on: September 26, 2008, 06:56:10 AM »
 nitrous
grudd440
« Reply #6 on: September 26, 2008, 08:42:02 AM »
My friend has a 1966 monaco and he used to take off the hood. I would run a vacuum secondary carb with that heavy car.
440 DusterDemon
SRT440DUSTER
« Reply #7 on: September 26, 2008, 07:17:21 PM »
You said not stock. What isnt stock? What cam, Heads, Intake, Exhaust, Carb?
2005 SRT-4 (307 fwhp) 12.97 @ 110mph on Street Tires
1972 Duster 440 13.20 on one leg
1970 Coronet 4dr 440 - 11.90
chryco
« Reply #8 on: September 26, 2008, 08:43:28 PM »
dartracer
Strasburg CO.
« Reply #9 on: September 26, 2008, 10:38:56 PM »
If you run the 1/8th mile, some 5.38s should do the trick. Need more info on the motor, fix the carb and fuel pump.
speedymopars
« Reply #10 on: September 26, 2008, 11:39:48 PM »
1) do you have good headers and a full 3 inch exhaust with X pipe?
2) Do you have a performer RPM or a performer with 1 inch open spacer with the EGR port blocked off?
3) A big TQ or a large vacc secondary holley?
4) A full port job on the heads, or better still some good flowing AL heads?
5) a good NOS system?
6) A cam with around 245 duration @ .050?
Upgrades ... 543 ci stroker....JMHO
moparbubba
« Reply #11 on: October 12, 2008, 01:04:34 AM »
Lose weight, or go with as much gear possible. Or both. I raced a 69 Gran Coupe in the late 70s in Denver. I couldn't beat many Cameros, but beat a lot of cars I shouldn't have. It was respectable. I had a 383, 4.56 gears, Street Dominator, Holly 650 Vac, stock dual exhaust. I scrapped all I could from the car. Got it down to 4000 # without me in it. A lot ov Chevie boys thought it was a 440.
67Dart34dr0
« Reply #12 on: October 12, 2008, 08:07:45 AM »
Take off the doors, trunk, and hood.  Grin (or not...)
I'd say first to take apart the interior trim, then take out the backseat, if it has buckets use just one, take off the exterior trim, the hood coming off may be a good suggestion as long as it's prepped right (should be...)
Ever heard of a 383 dual quad intake? (stock piece) This could be worth a bit of power plus a pair of nice carbs. Either that or an alum intake if you don't have one.
1967 Dodge Dart 270 4-door
moparbubba
« Reply #13 on: October 12, 2008, 02:48:28 PM »
If I remember correctly, my front bucket seats in the Gran Coupe were like 75 # each. They were power buckets. I bought 2  plastic racing seats. Like 5 # each. The carpeting, hood insulation, wheels, intake manifold, and anything that wasn't needed were replaced adding up the pounds. Every 100 pounds is a tenth or better in the quarter mile. In a quarter mile, at 100 mph, a tenth is a car-length. That's a bunch...........
