Topic: anyone know much about 50's dodge's? (Read 270 times)
MyCreation68
I'm looking at buying up this 54 dodge regent I found,I was looking at a 52 that i had posted about but I like the look of this 54. I just really need to find out what width of a stock 54dodge is wheel to wheel and see about putting a volare front end under the car and a volare rear end under the rear. Install a slant 6 and a 904 auto and drive it this winter.
Teach a child to be polite and courteous and, when he grows up, he'll never be able to merge his car onto the freeway. -98 Dodge Ram SS/T 5.9L auto all stock -92 Dodge Power Ram W250 5.9L CTD 5spd 4x4 -68 Dodge Dart GT 6cyl auto buckets console work in progress -46 Fargo
MyCreation68
 corrected
MyCreation68
 yeah the regent should be about 73" wide and so is the F body Aspen so it should be swapable. I coulc have the drivetrain together in a pretty short amount of time The transmission from the dart would be used(the fluid was a nice red and didn't smell burned so I think it should be decent. The 79 slant I'd use looks to be a good motor. From what it looks like I could ether use the factory 54 suspension or parts but I think upgrading would be in my best interest.
doug 371
do u guys still have that parts car that u used all the parts on ur bro's car?
ValiantOne
pics, pics pics!!!
Pedalkisses
Show me the pictures of the car and I'll tell you all I know about it!
This too shall pass...
MyCreation68
the car is gone but there are still quite a few parts from it.
MyCreation68
actually doug depending on what happens I might be buying a diplomat just for the engine(to fix the ramcharger_I broke something again and now it's down to 6 cylinders) and I'll use the suspension and driveline under the 54.
rarefish
I'm a little lost. Do you still have the original drive train to the 54? If it had a V8 and you want to do a /6 motor swap I'd be interested in the old motor, Joe.
KEEP THE FAITH 56 Zodiac 66 Fury III convert 68 Formula S 383 4spd convert 85 Ram Charger 96 Ram Jayco conversion
doug 371
i got the 88 318 if u need it
MyCreation68
sorry no motor or trans
67Dart34dr0
You gonna hop up the slant any or is it gonna be swapped later?
MyCreation68
I'll probably just leaver stock for now. I'll play around with it later I just want to be able to get it running. theres enough work as it is I figure I'll pick up a set of cheap guages to monitor the vitals, temp, oil press, and voltage, and use my garmin GPS unit as my speedo(it logs mph and kph but I'll likely install a temporary mph guage just to be safe) I'll do this just so I can simplify things and get the stock cluster upgraded next year.
MyCreation68
i got the 88 318 if u need it  hey doug wanna pm me some info on that 88 318 and how much you'd take for it?
MyCreation68
Anyone ever driven something from this era? I may just keep it simple and leave the stock brakes and suspension for the winter and research a better suspension swap.
