December 04, 2008, 12:40:59 PM
| | |-+  stealth valve springs
Author Topic: stealth valve springs  (Read 232 times)
mick1967
« on: September 28, 2008, 02:25:16 PM »
 \/][ looking for some info ,i have a set of new stealth heads i am using  with a mopar performance cam kit it comes with new  double valve springs can i just switch them over with out sending to a machine shop,second question would it hurt to clean up the the intake and exhuast ports because they seem to be very porous rough
therocks
Re: stealth valve springs
« Reply #1 on: September 28, 2008, 07:17:14 PM »
Depemds what cam amd springs you have.The new springs have to be checked for installed height and coil bind amd you have to check the retainers also.I only changed mine because my car is 4 speed and a soled cam that sees 6500 or more all the time.My machinist checked the Source springs and said the would be ok for a htd cam and auto.I installed Comp duals ans retainers and keepers.My total was 200 bucks for him to swap it all 2 head gaskets and he unshrouded the valves amd back cut my valves and cleaned the seatd a tad.Rocky
ksdartguy
« Reply #2 on: September 29, 2008, 12:09:56 PM »
What MP cam are you running? Like stated, you need to check the installed height and the springs should go with the cam.
As far as clean up, I spent a couple hours working on my stealth heads and had my machinest backcut the valves and re touch the valve job.
They are working well as my 500 is pushing the Dart to 10s with 3.54 gear and all steel bodied street car. Cheesy
 bbd sign
mick1967
« Reply #3 on: September 29, 2008, 04:52:22 PM »
the cam i am using is a mopar 509 lift 292 on the intake and exhaust hyd with 440 source roller rockers
jyrki
« Reply #4 on: September 30, 2008, 03:31:14 AM »
The stock Stealth springs should be all you need, the ones I've measured have had about 110-120 lbs seat pressure. I would change the locks to machined ones though.
ksdartguy
« Reply #5 on: September 30, 2008, 09:05:37 AM »
