Topic: Picked up another Dart/ 67 HT this time 273 I have a question? or 5 (Read 252 times)
LAWFISH
I am buying or should I say buying back a 67 Drat HT I sold to a buddy a few years back dirt cheap. hes decided hes done with cars and has never started this car, so I am giving him what he paid for it and buying it now that my 67 POST car is 90 percent done. Its a red car originally and a column shift 273 car. I am hoping it runs as I never tried as I was putting the 340 into something and decided to use the post car.
Now, if the 273 runs well, I plan on leaving it for a while as a driver. What kind of mileage are you getting on your 273 cars.
I plan on Eventually using a big block or HEMI and doing a clone HEMI or bigblock car. Who is where is th ebst place to buy a HEMI hood or the six pack style scoop, the low and or high styles I have not decided which I like best. Thanks for any info.
Dave
LAYING DOWN SOME MOPAR JUSTICE 70 CUDA DRAG POLICE CAR 67 Dart POST 340-6 prokect and more 70 440-6 CUDA VERT
67Dart34dr0
I've heard around 16 city and 23 highway, but expect 13/18 for a car with an engine that "runs" and not much else.
Here's my question: is it a 273 2 or 4?
DART VADER
My Satellite has a stock 318/auto with 2.90's out back and I get about 18-20 mpg.
 tried and true
I got as high as 15.5 in my old 66 Dart around town (273 four barrel/904/2.93) and as high as 18 on the highway with the same engine in my old 66 Barracuda (four speed with 3.23s).
LAWFISH
Thats a great question. When I owned it originally, I was going to take the motor out and go big block or HP. So when I get it back I will have to check. I guess I was just assuming it was a 2 barrel, but really dont know for sure. I do know that for now I am just going to try and get it running and drive it. I may see if I have th eparts t make it a console shift and do that only for the time being. Dave
67Dart34dr0
If it's a factory 4 barrel, you'll get around the gas mileage of Jim's, if it's a factory 2, you might do a little better.
I've heard the 273-2's do pretty well in A-bodies, but most of them I've heard of were post cars, cheap 4-doors, Barracudas, and Valiants so it'd probably do worse than those. I get about 13 city and 18 highway with my 340, 727, and 3.23 open diff. It doesn't like going under 55, but is happy to go over it.
MVRCorp
My 67-273, 2V has about 6K on the engine with a three speed. I punched it .030, dropped in a mild Isky cam and ran dual 2-1/2" pipes with turbo mufflers out the back. Sounds mean and gets 21 MPG. Stock 2-V heads, by the way.
rarefish
I had a 67 273 4spd Cuda back in the 70's. I think it had something like 297 gears. I tried to see how good of gas milage I could squeeze out of it. On a long trip to the beach I kept the speed to 55, whole trip was highway, and I got a solid 27 MPG. After that I went to headers, intake, carb, and Camando cam and have no realistic data, Joe.
KEEP THE FAITH 56 Zodiac 66 Fury III convert 68 Formula S 383 4spd convert 85 Ram Charger 96 Ram Jayco conversion
69 Dartified
My 69 Dart GT has a 273 4bbl with headers, 904 transmission, and 2.93 gears and I was getting 25 mpg. I am not driving it now because it is being upgraded to big block.
LAWFISH
My 69 Dart GT has a 273 4bbl with headers, 904 transmission, and 2.93 gears and I was getting 25 mpg. I am not driving it now because it is beinng upgraded to big block.
Are most 67 273 Dart equipe with 904s or 727s? Just curious. If I make any changes to this at all for the moment, it will be a set of buckets and a console and shifter. This sooner or later will also be abig block for I am just finishing up the 67 POST 340-6 dart, so that will be enough fror now and I have other cars as well, so the thirst is no so bad. Dave
russ446
my experience is just with my '65 cuda but i believe 273's came with 904's.
67Dart34dr0
Are most 67 273 Dart equipe with 904s or 727s? Just curious. If I make any changes to this at all for the moment, it will be a set of buckets and a console and shifter. This sooner or later will also be abig block for I am just finishing up the 67 POST 340-6 dart, so that will be enough fror now and I have other cars as well, so the thirst is no so bad. Dave 904s, don't think 727 was used on smallblocks till '68. If the car was a GT it should have buckets unless it's a convertible...
69 Dartified
Are most 67 273 Dart equipe with 904s or 727s? Just curious. If I make any changes to this at all for the moment, it will be a set of buckets and a console and shifter. This sooner or later will also be abig block for I am just finishing up the 67 POST 340-6 dart, so that will be enough fror now and I have other cars as well, so the thirst is no so bad. Dave 904s, don't think 727 was used on smallblocks till '68. If the car was a GT it should have buckets unless it's a convertible... Correct me if I'm wrong, but I do believe that 727's were used on the 340 or big block versions only. Also, they mostly had the 7 1/4 rearend setup as well. The GTS had the 8 3/4. Also, you might check out your VIN to see exactly what you have there.
67Dart34dr0
Are most 67 273 Dart equipe with 904s or 727s? Just curious. If I make any changes to this at all for the moment, it will be a set of buckets and a console and shifter. This sooner or later will also be abig block for I am just finishing up the 67 POST 340-6 dart, so that will be enough fror now and I have other cars as well, so the thirst is no so bad. Dave 904s, don't think 727 was used on smallblocks till '68. If the car was a GT it should have buckets unless it's a convertible... Correct me if I'm wrong, but I do believe that 727's were used on the 340 or big block versions only. Also, they mostly had the 7 1/4 rearend setup as well. The GTS had the 8 3/4. Also, you might check out your VIN to see exactly what you have there.  I know most 273-2s had 7-1/4"s and I know a LOT of earlier 273-4s had 7-1/4"s, but I think after '65 they became pretty commonplace on 273-4 cars. Yeah, the 340s and big blocks used 727s but the big blocks aren't small blocks and the 340s came out for '68.  D is a 273-2 car, E is a 273-4 car, B is a 225... it's the fifth character. D is moderately common, B is probably the most common hands-down, and E is not as rare as you might think. Does that mean an E car ain't worth keeping original? Absolutely not, even a D car is worth keeping orginal maybe 8k for a D car and 15k for an E car.
