December 04, 2008, 07:23:32 PM
| | |-+  Core plug question?
Author Topic: Core plug question?  (Read 123 times)
valiant171
Core plug question?
« on: September 29, 2008, 09:38:49 PM »
I am finally going to pull my motor this week because of the lack of mine able to hold water...It is just the plugs, any tips or tricks?
75Dart440
Re: Core plug question?
« Reply #1 on: September 29, 2008, 10:15:02 PM »
While I had my 440 out and sitting on the floor, I pulled each core plug out of the block and flushed with high pressure water while using a piece of coat hanger to scrape around inside the bottoms of the water jackets to loosen up any rust or sediment.
I use permatex gask-a-cinch (or whatever it is called) around the opening in the block as well as the edge of the core plug and pound it in with an appropriate sized socket.
1975 Dodge Dart Sport - 440
2000 Dodge Ram 1500 QC 4x4
440WIP
« Reply #2 on: September 29, 2008, 11:54:54 PM »
I always use brass plugs and stake them in.
Daryl
"I've never met a $100 bill I didn't like"
valiant171
« Reply #3 on: September 30, 2008, 10:47:30 PM »
I did pony up the extra 2 bucks for brass Roll Eyes  why would people buy steel?  So it is as pretty much strait forward as i thought, thanks   Can i drive them in too far or do they just stop?
jbarker
« Reply #4 on: September 30, 2008, 11:05:59 PM »
Yes, you can pound them in too far.  If you do, you'll drop in into the block and will ruin the core plug trying to get it back out.  Not a big deal, but then you need another plug.  I pounded mine in until the edge was about 1/16" past the outermost part of the hole in the block.
