December 04, 2008, 07:21:19 PM
| | |-+  aftermarket steering coupling
Author Topic: aftermarket steering coupling  (Read 186 times)
68prostdart
« on: September 29, 2008, 10:02:56 PM »
I'm looking for a new coupling for my 1968 dart with manual steering. The original pot coupling is comming apart. What size is the shaft and how many splines? Is there an easy way to remove the old coupling? Thanks.
68' Dart 69' 440, purple 590 cam, .30 over, holley 850, 727 man shift, 8 3/4 3.91 motive, dynamic 9.5, csr pump
99' 2500 dodge diesel
fourspeed
Wisconsin
Re: aftermarket steering coupling
« Reply #1 on: September 30, 2008, 01:06:02 AM »
I don't know all the answers to your questions, but I recommend you call Bill. Contact info: https://www.reillymotorsports.com/contact.shtml
He can hook you up with a Flaming River joint and he knows what fits.
As for getting the old coupling off, check this out: http://www.fourbarrel.com/steeringcolumn.html
Of course, that assumes you got the coupling off the steering box, which can be a chore. It's just the way it looks - remove the roll pin, then pull the coupler off the steering box splines. The roll pin can put up a fight, though. Make sure you support the bottom if you use a drift punch and hammer.
