December 04, 2008, 07:24:32 PM
| | |-+  Anyone running an oil pan that has the center link running through it?
Author Topic: Anyone running an oil pan that has the center link running through it?  (Read 231 times)
1DART440
« on: September 30, 2008, 09:06:40 PM »
I am considering building an oil pan with the center link running through it, the low sump that I have now is too dangerous. I saw a pan like like this in the old DC racers book. I am wondering if there are any issues getting the link through the pan? Also I haven't looked at it myself yet, the car is covered up in a corner while I clean the junk out of my garage. From what I remember it should be a clear shot right through below the rails.
Re: Anyone running an oil pan that has the center link running through it?
« Reply #1 on: September 30, 2008, 09:09:00 PM »
I had one on my 64 belvedere ... it was a little bit of a pain in the ass to pull the cross link when it was time to pull the motor but over all it worked well ...
deepockets
« Reply #2 on: September 30, 2008, 10:49:26 PM »
i got a charlies and it's a really nice piece......... but i still had to cut and raise the upper part as the right side of the bar would hit. just a little of time on my end and $80.00 at the welding shop
Dodgeboy
« Reply #3 on: September 30, 2008, 11:19:57 PM »
Is this going to be a BB in an A body?
Roger
« Reply #4 on: October 01, 2008, 07:35:43 AM »
ya...we got that on the small block stroker...its not bad once you've done it a couple times  Roll Eyes
Blue
« Reply #5 on: October 01, 2008, 07:57:09 AM »
Used to run one years ago in a big block Duster, depending on engine placement you might have to mod it it for clearance. Other than being a PITA to remove the pan or pull the motor, they work fine.
bigtimeauto
Plymouth meeting, PA
« Reply #6 on: October 02, 2008, 09:27:05 AM »
The problem with them is if you plan on going faster than 9.99 at a nhra track you won't be able to put a diaper on it for next year. (unless they push the rule back again)
Bob
www.bigtimeauto.com
Procharger dealer
NOS refills
Dodgeboy
« Reply #7 on: October 02, 2008, 09:38:21 AM »
I managed to get an 8 quart pan in my BB dart by extending the sump to the rear about 2" and to the left side about 1". It only hangs below the K frame about 1/2". These dimensions I gave here are not exact but I will measure it if you want.
Roger
warthog
« Reply #8 on: October 02, 2008, 09:43:29 AM »
Sound like my way of doing things.  I thinking about the same thing.  Your dimensions would be a big help.   Thanks  Dan
Roger
1DART440
« Reply #9 on: October 02, 2008, 08:45:05 PM »
Roger
Sounds like another option. I certainly will consider looking at something like that.  Thanks for the input guys!
