December 04, 2008, 07:10:04 PM
| | |-+  dana 60 jig
Author Topic: dana 60 jig  (Read 375 times)
69satelite
dana 60 jig
« on: October 01, 2008, 05:33:32 PM »
does anyone out there have pics of a jig for the dana 60 or any ideas of how to build one thanks
Allentown, PA
Re: dana 60 jig
« Reply #1 on: October 01, 2008, 06:26:57 PM »
it is not a jig so to speak .... it is a long pice of centerless gound 1" bar stock with adapters made to fit inside the housing ends and inside the carrier caps.  the adapters are bolted into the carrier caps, the n the bar stock is slid in and then the hosing ends are put over the bar , then the hosing end adapters are slid on the bar and hold the ends inline with the carrier caps.
74fldart
Re: dana 60 jig
« Reply #2 on: October 01, 2008, 06:39:39 PM »
go to some of the axle companies sites, three is a pic at one, i cant remeber which.i know one of them sells one. maybe its  mark williams
lake worth, florida
55robert@comcast.net
Re: dana 60 jig
« Reply #3 on: October 01, 2008, 09:14:31 PM »
are you narrowing a car or truck dana?
69-DART
Re: dana 60 jig
« Reply #4 on: October 02, 2008, 10:11:52 AM »
I'M DOING A TRUCK 60?
FastmOp
Re: dana 60 jig
« Reply #5 on: October 02, 2008, 12:03:37 PM »
I use to have pics but cant find them. I narrowed my dana with a home made Jig. You need two pucks with holes in them that fit were the bearings on your sure grip install. then one that fits into the ends your using. all these have the same size hole in them that you slide a bar through, i used a piece of moly roll bar tube. Slide the roll bar tube through the two pucks in the housing, then slide the one that fits the ends onto the tube. This is how you make it true to the carrier and no miss alighned  ends. then tack the end in several places and finish weld.
69satelite
Re: dana 60 jig
« Reply #6 on: October 02, 2008, 04:56:50 PM »
truckrearend
GON_RACIN
Happiness is a warm gun.
Re: dana 60 jig
« Reply #7 on: October 02, 2008, 06:35:11 PM »
Narrowing jig that I made for an 8 3/4.  A Dana jig would be built the same way.  Centerless ground barstock and some machined pucks to align the carrier bearings with the housing ends.
69-DART
Re: dana 60 jig
« Reply #8 on: October 02, 2008, 06:41:12 PM »
YOU SAYING THE PUCKS WOULD BE THE SAME FOR 60 AS THE 8 / 34 AS WELL?
GON_RACIN
Re: dana 60 jig
« Reply #9 on: October 02, 2008, 06:44:23 PM »
Nope.  I'm saying it would have the same basic design.  The outside diameter of the pucks would be different, as the Dana  uses different bearings.
1DART440
Re: dana 60 jig
« Reply #10 on: October 02, 2008, 08:40:54 PM »
You can put whatever ends on that you want. I built a Dana60 20 years ago and put ends on from a 8 3/4 that I cut off a donor.
69satelite
Re: dana 60 jig
« Reply #11 on: October 03, 2008, 12:38:19 PM »
thanks thats what I was looking for I dont have any machining tools to make any of that stuff do you know anybody that sells it reasonably?
GON_RACIN
Re: dana 60 jig
« Reply #12 on: October 03, 2008, 06:31:30 PM »
Mark Williams sells them and I think Competetion Engineering sells them aswell.  It would most certainly be cheaper to just take the housing to someone who has the tools and let them narrow it for you, as opposed to buying a jig and doing it yourself.
74fldart
Re: dana 60 jig
« Reply #13 on: October 04, 2008, 07:55:33 PM »
i was in the same situation back a few months and i found a local shop to weld the ends on with his jig for $130.00 it seems like alot for just welding, but when i priced making my own bar up it was cheaper to just pay the shop, unless you plan on doing this more.
i priced the parts for making my own jig , the bar itself was $100.00 then the pucks , to get them made  who knows what that would cost , as i dont have access to a lathe .
69satelite
Re: dana 60 jig
« Reply #14 on: October 06, 2008, 09:40:53 PM »
know of any good axle guys in saint paul minneapolis area?
