November 20, 2008, 12:35:28 PM
| | |-+  ANYONE
Author Topic: ANYONE  (Read 623 times)
69-DART
ANYONE
« on: October 07, 2008, 02:09:28 PM »
ANYONE RUN FIT A 12" WIDE RIM UNDER THEIR 67-69 WITH JUST A MINITUB AND RELOCATED SPRINGS
IF SO ANYTHING I SHOULD KNOW ABOUT DOING IT..IF NOT, WHAT IS THE WIDEST YOU'VE HEARD OR KNOW OF
THNX
dd69a
Re: ANYONE
« Reply #1 on: October 07, 2008, 06:02:35 PM »
theres a guy on here BIGTIMEAUTO who i belive is running a 15x12 in his 69,talk to him. i think he has some pics, i belive the only difference is he has a aftermarket tubb in stead of widening the factory ones, it looks sweet!!!
mischiefdart
Re: ANYONE
« Reply #2 on: October 07, 2008, 06:18:44 PM »
My '70 Dart has the same width wheel opening as the '67/'69 cars. It is minitub with springs relocated. There is no need for a 12" wide rim. I have 15x10's with 325-50-15 mickey's and they only barely fit. Opening is 14" and sectional width of tires is 13.5".
dd69a
Re: ANYONE
« Reply #3 on: October 07, 2008, 11:00:44 PM »
hey got any pics of that tire set up mischiefdart,i also bought 325-50-15 still deciding on rims.
Birdius Rapidus
Re: ANYONE
« Reply #4 on: October 07, 2008, 11:35:32 PM »
I have your tires. A 12" wheel won't work on a mintub and relocate.
69-DART
Re: ANYONE
« Reply #5 on: October 08, 2008, 12:17:15 PM »
MORE OF A PREFERENCE THAN A NECESSITY REALLY
RIGHT. YOU HAVE ROUGHLY A 12" WIDE TIRE ON 10" WHEEL.. I THINK I WOULD HAVE ROUGHLY THE SAME CLEARANCE GOING WITH A LARGER AND WIDER WHEEL WITH A
LOWER PROFILE TIRE
IN OTHER WORD: FROM THE FRAME RAIL/SPRING TO INSIDE LIP OF THE QUARTER IS 14"
AND THE CARCASS OF YOUR TIRE IS ROUGHLY 13.5" ?
dd69a
Re: ANYONE
« Reply #6 on: October 08, 2008, 12:27:26 PM »
go to the off topic section of the forum, i posted a sec. about mini tubb pics, bigtimeauto has a pis there of his orange 69 with 12''inch rims,not sure of the mods though.
Bill_Reilly
Administrator
White Haven, PA
Re: ANYONE
« Reply #7 on: October 08, 2008, 03:58:25 PM »
By doing that work you'll end up with 14-14.5" OF AIR SPACE  to work with. What you put in there is up to you, however for street driving without rubbing anything you should have a min. of 3/4" airspace on each side of the tire. Less than that will hit the sides. So that gives you 12.5-13" sidewall-to-sidewall(sectionwidth). But keep in mind, advertised section width is measured on the recommended rim width - if you use a wider rim, the section width will increase, so you have to account for that.
  Even low-profile tires(35 series) stick out about 1/2" from the rim, so on a 12" rim, you'll be at 13", which is about the limits, but this is assuming you can find the perfect sized 35-series tire to fit on a 12" wheel.
  You can do it, but you'd have to be careful with dimensions and backspacing on the rim because there will be no room for error.
Bill_Reilly
Administrator
White Haven, PA
Re: ANYONE
« Reply #8 on: October 08, 2008, 04:02:01 PM »
Also, if you find some kind of specialty tire size that works, be warned that if it's not a popular or common size, it can be discontinued at any time - I had this happen to a couple guys last year that bought tire sizes used on a particular model Porsche - by the time the cars were finished, the tire sizes were no longer available, which forced them to order another set of custom rims that would allow a more commonly available tire size - those guys were pissed....
Crazy68Dart
Re: ANYONE
« Reply #9 on: October 09, 2008, 10:06:34 PM »
It can be done, but like Bill said, you better be nuts on with the measuring and selection.  I have 17"x11" wheels w/ 315/35s, and there is probably a touch over an inch of clearance on both sides.  Once these tires "wear out"  Smiley  I might go with a 335/35.  I'm pretty sure they will fit, but even that is pushing it...  This is with the wells opened up and figuring in some trimming on the quarter panel lips.
69-DART
Re: ANYONE
« Reply #10 on: October 10, 2008, 10:43:54 AM »
thanks for the insight everyone...i will take pics and keep every one posted
THINK 20 X 12 Grin
olddart
Re: ANYONE
« Reply #11 on: October 11, 2008, 09:24:43 PM »
Mine are 295-50-15 on 10's and they fill the opening nicely but the chassis guy said I could push and get the 12's but it looked like trouble
