Topic: Bolt In 4 Link Challenger on MuscleCar TV????? (Read 1685 times)
Did anyone see Muscle Car TV this weekend? They're putting a "bolt in" 4 Link suspension (with air bags) in that Challenger they're building. However, I didn't catch anything about who makes it. Anybody see it and catch the manufacturer name??? Would be interesting to look into for an A body. Thanks... O.J.
Musclecar tv used a new rear kit from AirRide. B and E only though - So I'm doing one for the A's - I've been messing with air ride in the alterktion and I like it so much I just have to make the rear kit.
oh man the cat is outta of the bag...
For real, for real? Oh Man I can't wait to see this!!!!
MikeR
Bill, you made an air bag version for the front??
I've been talking with Air Ride for months now about it and they came out with a new one recently that bolts right into the A-body alterktion. It's a little shorter than the current coil-over I'm using, so the ride height is a little lower. But, at the correct height for the shock, it's right where I like it. The cross bar on the frame is about 4" off the ground. And with a 26" tire, I can lower it 3" from there - too low obviously to drive, but it looks neat sitting there that low. I didn't bottom out anywhere around here(which is really saying something), but I'm going to change my oil pan anyway since it's just a street car. But lowering isn't my reason for it... What REALLY has me excited about it is the ride quality - it's absolutely smooth as glass. I'm totally amazed how nice the car drives with them - that's what prompted me to do the a-body rear - I have to have it in my own car. Initially I thought air ride was just a bunch of bling, but I'm sold on the stuff. I never thought my Dart would ride this nice and still handle. As for retrofitting, anyone with an A-body alterktion that has the 10-14" travel shocks can use them. Older systems that had the short shocks don't have enough room. Also, the B and E body systems need a little modifying so none of them can be retro-fit. Well, they need longer a-arms to widen the track a little to make room, the frame would be the same. Still an added cost though, so I'm not counting on many people changing over. Soooo, I'm now a dealer for Air Ride. We'll have the alterktion's with an air ride option, the bolt in B and E rear air 4-bars, and I'll be doing the rear air 4-bar for the a-bodies. The A-body rear shocks may have clearance issues with the gas tank, but I have more work to do yet, so I'm not sure at this point... I'd put some pictures up, but I have my car all torn apart.........AGAIN. I just can't keep this thing together for more than 3 months at a time.
lowmopr
At Last, people are now realizing the potential of putting airbags on mopars, not only does it look good slammed, but you get a good ride. I am glad your making an airide option for the AlterK and making a 4 link airbar for the back. Saves the work I have to do trying to figure it out. I am going to body my valiant to get rid of that gap so I lay my body on the ground also along with the subframe. My little minitruck is soon to be on airbags. they are quite nice.
-Mike
shine is fine but flat's where its at
kowski71400
are you going to offer a 4 link without air bags for the poor people (like me)?
Once the shockwaves are fit, coil-overs will fit with room to spare. It'd be a simple choice, one or the other.
vitamindart
will the 4 link kit work with the leafs moved in???or in the stock location
sycboi
I believe it replaces the springs man!
sr71mopar
Do you fill these bags like air shocks, or do they have leveling valves and an air supply?
You could just put a stem valve on the line, but they have full compressor systems for them. Check out www.ridetech.com - The RidePro is the compressor system - there are quite a few different compressors based on cost. The front shockwaves I'm using are listed there as V3.0, and the rears are the 9000 series.
392dart
what are you going to do for bolt in applications with the springs moved inboard since the mounting points would be different . I really would like to slam my hemi dart and four link would be awsome
392dart
i am stupid the points are not different
azz7772
hey bill what is the time frame till your ready to sell the four link rears? and what rear ends will work just the 8.75 or the dana 60 as well? i am not far from doing alterk and rear suspension.also where were you thinking of mounting the compressor set up?
mrspeeddemon
oh sure-all this cool stuff coming out and me with no money  oh well I quess I'l just have to save a little longer! ![\/][](http://www.bigblockdart.com/Smileys/classic/finger020.gif)
vitamindart
I believe it replaces the springs man! no meant will the bars be in the stock location or inboard for tire clearance
Megajoltman
Man  Bill do you ever sleep this sound so cool
building a 69 383 dart
Daily Driver 1998 Ram CTD 12V 4x4 Quad Cab Auto Shortbox, 3in Carli lift with custom rear lift springs (no factory blocks anymore) DSS Steering Stabilizer, 315 Toyo Open Country M/T tires
The lower links will bolt into the existing mounts, wherever they might be.
Time frame on the rear kits will most likely be a while. I'm working on it in the Dart, but I have a couple hundred other projects going, so the actual for sale parts will be done as I can fit it in...
I was never very good at sleeping - time enough for that in the grave.
rumblefish
Bill, on behalf of mopar fans everywhere i would like to say....
ThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThank youThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyou ThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThank youThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyou ThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThank youThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyou ThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThank youThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyou ThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThank youThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyou ThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyouThankyou!!!!!!!!
I finally got to see the kit at a show this weekend. I think the kit Bill has made is much better.
Think3205
the kit sounds awesome! btw would one of those projects be adding a sway bar to the rear suspension kit that you have out now?
Actually, yea. When I get to reassembling my car I'm going to work one out. I'm PRAYING I get to my car over the winter....
Think3205
alright sweet, i will eventually buy the alter-k with the sway bar option and i wanted to get the rear kit as well but i was hoping to see a sway bar for that as well... glad to hear it! thanks for the reply! -Ben
