Topic: Major Noob, Fab'r here, Rear suspension fab true/level??????'s (Read 326 times)
ESSVEE
Hi all,
Going to relocate my rear axle and minitub, My question is I don't know a thing about how to level the car, too ground? Maybe use a line level? I'm up in the dark here...any help on getting this straightned up. could use some step by step all the way through the project so I dont screw this up. havent really even used the plumb bob method.
Thanks, any help appreciated!!!
ESSVEE
Ok lots of you have looked still don't know a thing, come on guys any Help. Thanks in advance.
74swinger
AAOUTLAW
AWWWW C'mon....thats an easy one
There are a few point on the chassis that are important - you need to use those as reference points. The torsion bar socket in the crossmember is one, the front leaf spring eye is another.
Get the car in the air and make sure you have the same height from both spring eyes to the floor. Then check the torsion bar mounts and make sure they are both the same height from the floor. Measure the height of the rear frame rails where the shackle mounts and write it down (just in case).
Stick some jack stands under the rear frame in back of the rear leaf spring mount. Stick some wood wedges in there to fine-tune if necessary. This will support the back while you're working.
If your garage floor isn't reasonably level and flat, this won't work.
To align the front spring eyes, use two lengths of 5/8" ready rod and a coupler in the middle.
ESSVEE
 Thanks Fourspeed, I wanted to center my rear axle in my fenders so I can use a taller tire. I was thinking of just moving my mounts back while I am relocating my springs. Thats why I was talking about a plumb-bob. I have allready removed the rear end and didnt want to reinstall it. Is there a better way to move the axle back? My bad )(/*Duh  Measure from the floor, I honestly did'nt think of that however the floor really is not at all straight.
74swinger
That's what I needed to see! Thanks for the pics as well, pictures are worth a thousand words. On another note I noticed you have "new" steel in the rear wheels, but they don't look like Competition Engineering (or others) tubs. Did you use factory steel and widen them, replaced the factory wheel with aftermarket steel and widened them, fabricated from scratch? Would you do anything different if you had to do it again? Be patient and kind, I am new to this.  I'm doing (  ) a '74 Swinger with a 400, 727 auto, but I'm just starting. Don't even have a block yet!
