December 03, 2008, 12:11:03 AM
| | |-+  PST Front Swaybar
Author Topic: PST Front Swaybar  (Read 201 times)
LoneStarMopar
PST Front Swaybar
« on: March 15, 2006, 01:43:08 PM »
Ordered PST poly front end kit for a 69 Dart and let myself get talked into their front swaybar too. The Dart did not come with the stock swaybar. The brackets in the PST kit bolt in to the K member and shock bolt on the lower control arm. I had to do some grinding on the control arm bracket. But when putting the sway bar in, it seems about 2 inches too long. I mean the long bolts with bushings going from the ends of the sway bar to the control arm bracket are at a crazy angle (45 degrees measured at the bar). This can't be right. I haven't put the spindles on yet but I think they will hit the sway bar on a sharp inside turn. If I can figure this out I think I will weld in the brackets to the K member and control arms. But this length thing has me stumped. Maybe I got a B-Body sway bar? Anybody else installed a PST front swaybar?
mopowers
Re: PST Front Swaybar
« Reply #1 on: March 15, 2006, 01:50:26 PM »
If it were me, I would look at the part # they sent you and call them to verify that it's the right one.
2006 Dakota
70 Dustpan
Sacramento CA.
« Reply #2 on: March 15, 2006, 02:30:00 PM »
That's how the 67 to 72 sway bar is. It's higher in the back where is bolts to the control arms? Right?
Hey, I'm a God again!
Birdius Rapidus
« Reply #3 on: March 15, 2006, 11:16:34 PM »
You may have the bar. Anyone know what the proper center to center should be on his car? I ordered a '69 B body for my RR and I went to put it in it was about 3" too long each side. they sent me a '70 B body.
Tom
fourspeed
Wisconsin
« Reply #4 on: March 16, 2006, 02:17:14 AM »
Here's a pic of somebody's '72, which would have the same bar.
